2025 Ram 1500 Current Owners - Discussion, Feedback, and Problems
I had already posted this as a separate thread, but perhaps it should have been posted to this one. Any input would be much appreciated. I've since put probably 250 miles on the truck with no further problems.
New member here. Recently bought a new 25 limited specifically for towing a small travel trailer. While leaving hotel to pick up the new trailer, started truck cold in morning and had check engine light while idle was fluctuating and running rough. Drove .5 mile, then flashing check engine light came on, and became undriveable. Had towed to nearest dealer, and they found multiple misfire codes (write up says misfire to p0016-00 crankshaft/camshaft timing bank 1 sensor one and b0300 multiple cylinder, DTC card present p0301,2,3,4,5,6 present store codes). Dealer says they were told to erase all codes and test drive for 15 miles. Drove normally, and no codes returned. They also checked spark plug and crank and cam sensor connections, all fine. I cancelled the trailer pickup due to not wanting to risk a roadside problem with truck and trailer combo far from home. Truck drove nearly 100 miles home normally of course. Dealer told me that if recurs with flashing check engine light, could require engine tear down. This seems illogical to me, as it seems like more of a sensor related problem. Any insight from you folks would be appreciated. We're wanting to do some long trips with the new RV, but the idea of being stranded 1000 miles away from home on the side of the road with a trailer attached and vacation plans ruined by a major engine problem is not appealing. How concerned should I be at this point? Is this a very unusual occurrence? Suggestions on next steps...aside from driving it more to see if it recurs. Thank you.
Vince
Disconnect BOTH batteries......let them sit for awhile and reconnect them. You have some electrical gremlins that just happen to pop up once, then once they clear, they never show again. Almost 25,000 (s)miles on my HO Longhorn.....zero issues......no recalls, no warranty work, etc
Can you please tell me if there is any special procedure that needs to be done when reconnecting the batteries after disconnecting them? Is it enough to reconnect them and everything works correctly ?
Many Thanks.
Inviato dal mio SM-F766B utilizzando Tapatalk
Okay, I am a big old dumbA$$!!
I never tried that button. I thought that button was to turn on/off the mirror auto-dimming. Obviously, I did not look at it closely enough.
The button to the right of that turns on/off the interior lights. It never occurred to me that there would be second button there that ALSO turns the interior lights on/off.
DUUUUHHHH!!!
So, that button (on the left) does indeed turn off the interior lights for me when the tailgate is open.
And, it seems that when the interior lights are on or the driver's door is open, the wireless charger turns off. That is still dumb, I think. But, the wireless charger seems to work when the overhead lights are off and the door is closed, even if the tailgate is down.
So.... I am all good now. Thank GOD I didn't take it to the dealer and go through all that just for them to go "watch this" and then push that button... lolol!!!
Glad I saw this today. Hauled a table for a friend last night and had to leave the tailgate down....damn interior lights were on for 45 minutes while I drove to their house. I tried every button but the right one. Thanks for the info.
I am GLAD I am not the only one! :D
I created a separate thread with video.
Do any of y'all have the same issue, where having the tailgate open makes the interior overhead lights come on and they won't turn off? And the tailgate open makes the wireless phone charging pad not work?
Open door/tailgate and the wireless charger doesn’t work. Manual says so… well about the doors but I assume the gate counts as a door
Yes. But the question is: Why? What’s the reason behind that decision?
Perhaps ..... if you have an open door, it means that the truck/motor is off and the battery should to die.... perhaps
Maybe this all comes down to bad programming which a number of us have seen in these trucks. I absolutely agree that an open door with the truck off could/should turn off the chargers. An open door with the truck running absolutely should not turn the chargers off. Maybe they simply didn’t differentiate in their code from truck running vs off?
Peterhenric, yes ! This should be the ideal and correct way to manage the device...
Hey all. So I've had my 2025 Laramie for about 6 months now, 4.5K miles. I work from home so don't spend a lot of time in it. But I have noticed the drivers seat cushion is losing its shape already. I'm not a big guy (175lbs) and I am not rough on the seats at all. Anybody else notice something similar? I attached a photo of what it looks like when it hasn't been sat in for over a day.
My 2019 Laramie with the same exact leather/seats looked like this after a few months!
No problems after 5 1/2 years of ownership (totalled at 37K)
Thanks. Did it get worse over time? I'm thinking about having the dealership look at it.
lol mine do that
Not mine lol. It stays like that.
There has to be something wrong with the material they are using or the way the seats are constructed. My wife had a'16 Charger, '19 Charger, and currently a '24 Durango, all with the leather or whatever it is. None of them did this. My 10 year old Ram Big Horn with cloth seats look like new and no wrinkles.
To me it looks like excess material or not enough padding.
I know the stock rebel seats with leather and center squares are cloth are way better .
Thanks, I'm going to have a warranty inspection done.
  • Back
