Put fender flares today. what do yall think??
Those could be the best looking aftermarket fender flares I've seen on a truck. Love the subtle design with the OEM shape (but larger) and the small front indentations. Just the right amount of detail without over doing it. Where did you get these?
Those could be the best looking aftermarket fenders I've seen on a truck. Love the subtle design with the OEM shape (but larger) and the small front indentations. Just the right amount of detail without over doing it. Where did you get these?
Thanks! I agree with you. Wasn’t big fan of fender flares until I saw these. They are rough country SF1. I bought it from Amazon but their website has color match options as well.
yeah I like these, nicely done. Going to go take a look for my Big Horn maybe. I sort of miss the flares, it's why I went with 11.5" tires and kept OEM rims.
I just received my first Rough Country product today and installed, hard roll up cover. I ended up having to pull the rails back a tad to get a better seal at the rear of the bed, took a little playing with to get it where I wanted but quite happy with the result after 1 hour of ownership.
Might make it a weekend project
To bolt them on, use speed nuts or push on speed nuts. Just find the right diameter.
I think they are 3/16 or 5mm.
...at 7,343 miles had a local shop install the Pacbrake oil filter relocation kit #R160106 so I didn't have to get oily/dirty. Fumoto drain valve, Mobil 1 5W-20 and Mopar filter. I think I'll cap the drain nipple and secure with a hose clamp, for peace of mind in case an "act of nature" removes the clip and toggles the valve.
View attachment 207651 View attachment 207650
Won't happen (famous last words).
I had one on my 2001 ford diesel 7.3 Excursion for 21 years, not one problem or worry.
JMHO
Paul B
  • WFO2
