I will investigateCarli Rebel HD if you're gonna have ~500lb in the bed constant.
Ran a pair for ~2 years until I have more than 500lb constant
you welcome.I will investigateThank you
I could’ve looked it up myself. I thought maybe you had installed it on your truck. Thanks for going through the effort.Ah... manual says it's a strap and cambuckle for securing.
Walmart battery failed the load test, so I got a $25 warranty credit towards the new purchase.Looks like I'll be heading to Wally World later this morning to swap out my battery.
OE battery lasted 18 months.
Walmart H8 AGM lasted 40 months.
Edited for bad math before coffee.
Should do pretty well. I put Cquartz from CarPro on mine 6 years ago and it still beads but my truck is not a daily driver either. Definitely makes the liners easier to clean.View attachment 207512
We are going to see how well Cerakote holds up. I don't expect miracles do to the location but it'll interesting. I did them all.
Might want to update your signature - that doesn't look like a 2020 engine! lolBought an Improved Racing CCS High Efficiency Oil catch can, fittings, hose and built my own oil vapor catch can system.
Also ordered a 1" M6 hex nut, I'll raise it up a bit when that gets here
I have zero creativity and artsy ability, but I can appreciate it.Working on 2026 Calendars and decided to use my truck as one of the graphics for the "vehicle" themed version.
Also used the truck in the background of one of the Scenic themed one.
You can get a glimpse of them here:
2026 Monthly Calendars
CORE4X4 sway bar links. Bilstein, Eibach, ICON and forget who else makes rear coils. 1-1.5" Clayton makes Gladiator coils that fit the RAM as well.View attachment 207487
These just arrived!!! Need sway bar links and possibly rear coil suggestions
I couldn't believe how heavy these are! wOw
wow i am honored!I have zero creativity and artsy ability, but I can appreciate it.
I'm still using your truck as a background still. It maybe changed up in the future![]()
It's not that big of deal. I couldn't have been the only one that has used it. Good looking truckwow i am honored!
look up "color theory" when you have time hahahaIt's not that big of deal. I couldn't have been the only one that has used it. Good looking truck
I like the blue and the rims really look good. I would have never thought of doing that. Its impressive![]()
checked my coolant dip stick. it had what looked like a clump of mud on it and it is some kind of red coolant. i'm going with HOAT purple for dodge 2000 and up.
Prestone max it claims 15 year 350k mi. never need to flush again? we will see........
i'll keep a eye on that i didn't see any commination of oil in the drained coolant. sometimes the sand/mud in the dipstick is caused from the organic coolant evaporating from the overflow tank over the years. every time you change oil you should top off the rad and the overflow. i got it used so.......Make sure you don't have an oil cooler leak causing that "clump of mud" on the dipstick. When the engine is cool, check the radiator cap as well, clean up anything you see then check again later to see if you are still getting oil/water debris both on the dipstick and radiator cap.
If so, have your oil cooling lines, fittings and oil coolers inspected, it's common issue for them to leak and contaminate the cooling system.
