I have these issues. While traveling on the highway a big dip in the road caused some warning lights to come on like traction control. I’m going to check to see if I am grounding out at the axle/exhaust from a hard dip. I have just begun my journey with u0001 and a B235A code.You've got a grounding issue somewhere. For me, this happened when the top of the rear axle was hitting the exhaust and melted the wiring on top of axle. Every so often, it would hit the exhaust and cause a ground issue.
Yes a lot of people have replaced that to fix their issueThere is a sensor control behind the light controls left of the steering column. It’s green with a bunch of wires running to It. I pop that out and tug on that a little bit and it fixes the issue for the day. This is how I start every day. Has anyone had this specific piece replaced?
look on the first page sound like the star connectorThere is a sensor control behind the light controls left of the steering column. It’s green with a bunch of wires running to It. I pop that out and tug on that a little bit and it fixes the issue for the day. This is how I start every day. Has anyone had this specific piece replaced?
