Cargo Camera - Is it possible?
JRD
I know I’ve seen it mentioned in old threads, and I’ve seen the rear digital camera “HOW TO”. But what I’m looking for is the cargo camera like the 2500s.
When I see it mentioned in the old threads it says it can’t be done, but they’re like 2-3 years old. Has anyone dug into this, or attempted it? Unfortunately I have no mechanical skill, so I’m at the mercy of the HOW TO section.
It can be done, but not easy. You would need to modify your CHMSL to add the camera and then run the cables, etc.
Do you know if it is the same CHMSL people are using for the digital rear view? Another thing I’m not sure about is how it would look on the display, I would think it should look OEM on the screen since it’s an option on the 2500, thoughts?
Doesn't matter which CHMSL, you still need to add the extra camera.
I have a 3rd brake light & CHMSL for $400 out of a wrecked 2019 3500. Can anyone think of a reason this wouldn’t work or should I just pick up the parts? $400 seems like a fair deal based on what I’ve seen for new?
From what I remember, it doesn't match up since the cabs aren't the same.
What a bummer! I have a tonneau cover & when it’s flipped up you don’t know what’s happening back there.
Been a few months, but I added cargo cams to 4 work trucks ... Today I decided to add it to my Ram -- The added view is a plus..
-=FM45=-
I already installed the 2 input Digital Rearview Mirror but only have 1 camera in the CHMSL.
Will a trailer tow camera for a 3500/4500 work? Does it really matter which Digital Rearview mirror is being used?
I don't know for sure if the tow camera, but I'm pretty sure you need the same camera that is in the CHMSL.
What do you mean modify to add the camera? I just replaced the CHMSL with the one that had the camera already installed. And when I plugged that in to the DRVM I had just installed, it worked perfectly.
So your CHMSL has 2 cameras, one for rear view and one for cargo? If not, then what I said is true. This thread is about cargo cameras.
Sorry no. I mixed up my threads. I only have the rear view camera light.
But my digital rearview mirror is a two-input camera. I want to add a trailer cam and I'm trying to figure out if I can use any digital rearview mirror to do so.
And I answered that higher up. I'm pretty sure you need the same camera that is in the CHMSL. I believe the camera and mirror must match. I'm not 100% sure. You might be able to use the cameras from the 360 system, but I've never tried it.
