Where does that foam piece go? it just fell out when removing the liner
I think it goes in front of the door. Between the fender and the door. Go open the other front door and look in towards the fender and you should see the foam piece.
After owning my truck for more than 5 years, I finally decided to swap the OE Halogens out for some Amazon LEDs. Opted for the yellow fog lights, and I think they look pretty freaking sweet.
These things are much more difficult to change than the bulbs in my Olds, but Ive dealt with worse.
Thank you. Is there a common leak in this area? Seems like I read some thing but it could elsewhere... too much info in head.
Yes, there are some Ram owners that have experienced a leak in that area. I believe it is simply fixed with a sealant. The foam pad is just to cut down on vibration and wind noise, I’m sure.
do people use sound deadening in front fenders?
im not sure about our trucks but some manufactures do to block out rolling noise to create that quiet cabin. I know on some Lexus models they do.
i vaguely remember some of those stuff came out when I cut my fender to clear my tires for aggressive wheeling, but could be from other vehicles that I worked on at the time lol it's been a long time
