Intake Recommendations
Trooper91
Hello everyone! I’m new to the Ram family and recently picked up a 1500 with the SST engine — absolutely loving it so far! I know this has probably been asked before, but does anyone have a recommendation for an intake that gives a bit more sound? I’ve looked into the K&N, but it seems like the semi-open design might pull in hot air. Any suggestions or setups you’d recommend?
Welcome! K&N is known for their "high flow" which also means more dirt flow into the engine. I don't recommend them.
K&N filters absolutely let dirt into the engine. I used to work on dodge trucks with the cummins diesel, and I noticed that every one that had a k&n filter also had a detectable layer of fine silt or dust in the intake tract. You could wipe it off with your finger. Trucks with paper filters did not. That may not matter on an engine you've modified to the point that you're not expecting to get 100,000 miles out of it between rebuilds, but for something that you want to last, I would avoid it.
Whatever you decide, use DRY filter ONLY. Less chance for dirt, compared to oil and not worth the hassle either.
Don't worry about hot air with a turbo, it all goes through the intercooler.
Sounds like S&B with a dry filter might be the best bet. Is anyone running that set up?
Why?
Do you really believe that adding an air filter alone will significantly improve ride experience? The additional noise is fun for a few minutes. On long rides it is just background growl. You will not get any significant amount of power out of one mod. And K&N will get your money. Save your $, go get ice cream or whatever desert you like. Money better spent and happier rides.
Why?
Got to love when people worry how you spend your money :rolleyes::ROFLMAO::ROFLMAO:
I’ve always been an enthusiast, and while I agree the stock setup performs well, I’d like just a bit more sound. I understand the power gains won’t match what’s advertised, but I’m mainly looking for a little extra tone and character.
