Backup Camera Unavailable Fix! Reset didn't work
Nitewulf
FIX for me was to remove panel on tailgate, remove 4 screws to get camera out, installed a sheathed wire behind clip, and reinstalled plug to back of camera.
Background
Blue screen showed up starting camera unavailable, like so many before me. Unfortunately, the only "fix" I found was to give it to RAM to fix under warranty or reset radio by pressing power and tune buttons for 20 seconds. Since my truck is out of warranty and reset didn't work.... Completed fix above since my connector wasn't all the way in the camera and popped right off.
First picture has red arrow pointing to where I put the small wire with sheathing. Sorry I didn't take pictures, decided to write this hours after fixing it. My connector had masking tape on it. It appeared someone thought that would keep the connector in place. I figured it would happen again unless I put pressure on the locking tab, hence the wire with sheathing.
I hope this fix works for others and please let me know if clarification is needed.
Background
Yeah, masking tape will hold only for so long.
You could just order a replacement pink fakra H connector from amazon and swap the plastic connector housing, real easy to do.
I just ordered a 4 pack to build some T.S. cables.
Amazon.com: keisnoaja RF Coaxial Cable Connector, 4Pcs Fakra Video Connector H Female RG174 RG316 Cable Connector Crimp Solder for Car XM Radio GPS Telematics or Navigation Ships, Pink, 4XEB-014-0007-XGDX : Electronics
mine is out
but it flashes the view before going blue.
Could be the camera crapping out, they are not that expensive.
I would take it out and re-seat the connector couple times just in case the connection is not good.
The torx screws securing the handle assembly are a minor pain due to reach and angle. T-15 IIRC but don`t hold me to that.
it stopped flashing so I took the panel off and sure enough it was unplugged.
wife had to use her small hand to plug it back in, I than finished, and felt a click so am hoping it will stay plugged in.
all ok now.
Glad you got it working! Ridiculous that this happens to so many...
