Morenar
I ordered the core 4x4 sway bar rear end links and I know that with the Ram 1500 the top bolt will need to use the nut welded to the frame. Since the core end links did not come with instructions. How do I know what sleeve to use? What's the easiest way to remove the sleeve it came with if I need to?
