Which is your preferred off roading one?
I use Gaia on my motorcycles and f150/jkur, using an iPad in the ford and the jeep. Can I display gaia on my 12.1 screen?
i use Gaia and briefly used OnX.
I used Gaia on iPhone circa 2020 and that was quite a lot of processing needed to run GMap, Gaia, Spotify, Camera, all at the same time. So I got myself a cheapo Samsung Android Tablet (I think Tab A 7?) and it worked great for a year or so until the eventual android slowing down issue. It lagged when following the route, but was borderline unusable when trying to type.
From 2021-2024 I stuck with the Tab A, until prior to my trip to Alaska last year I was sponsored an iPad mini 6. It worked great, but I ran into issues downloading map layers after downlaoding the layers of my route through CA, OR, WA, BC, YT, AK, NWT, AB, MT, ID, UT, NV, and AZ. I think it was an iOS update that F it up or something, but I got it to work eventually.
Now, during my debacle with Gaia and iPad Mini 6 post trip (and right when I was about to leave for a nother 3 days 2 nights trip), I decided I had enough of this bull and tried OnX. Paid for a year's subscription and then learned I CANNOT download may layers like I do with Gaia. With Gaia, I usually mark the area that spans the route and the entire area of where I'm going, and download it (which usually is quite large area and large data).
That doesn't work with OnX. With OnX, the service limits the area that you can mark for map download, and then you'll have to piece them together. It is kind of like when you download offline maps for Google Maps. Same ideas. So because of that, I only used OnX once and scrapped it.
Can you use Gaia with the 12" display? Yes, you absolutely can! They make it Carplay compatible.
HOWEVER, it didn't work well for me. The map orientation was wrong, sometimes the marked route doesn't show up, there's lag time (as in, running it on the 12" display and tablet at the same time, tablet shows real time movement/ location while 12" display lags 2 seconds or so behind), the control is not as intuitive as it is on tablet. I tried this before getting the iPad as I was tired of the lag on the android tablet, and to be honest it was even worse.
This was back in early 2024 so things may have changed with new updates, etc.
The command center:
All these are mounted with:
-ICS Fabrication dash mount
-67Design arms and mounts (none of that bulletpoint fake made in US junk)
-Repurposed RAM mount for the HAM radio display
