Do the tires you have now rub at all in the wheel well?I've got 33x12.5R20's but I'm due for a new set of tires. Just curious if anyone is running 13.5" wide tires on stock rims.
You do realize a 13.5 wide tire isn't meant for stock wheel width? Shoot, the rock wheels are still bare minimum width for 12.5s, and that depends on the tire manufacturer.I've got 33x12.5R20's but I'm due for a new set of tires. Just curious if anyone is running 13.5" wide tires on stock rims.
I have a 2" level with 1.5" spacersDo the tires you have now rub at all in the wheel well?
I know but just curious if anyone tried itYou do realize a 13.5 wide tire isn't meant for stock wheel width? Shoot, the rock wheels are still bare minimum width for 12.5s, and that depends on the tire manufacturer.
13.5" wide in 33 or 35 fall within recommended rim width range starting at 8.5" wide. So yes stock rins cannot accept this tite size.. I am thinking to put this size in my stock 22s. Also curious if anyone has tried.You do realize a 13.5 wide tire isn't meant for stock wheel width? Shoot, the rock wheels are still bare minimum width for 12.5s, and that depends on the tire manufacturer.
I've never seen a 13.5 width tire that has listed 8.5 as minimum width for the wheel. Most start at 9.5 minimum, with some wanting 10" wide minimum. Your factory wheels are on my 9" wide. Any reputytire shop will not mount them to stock wheels. Of course you will find shops that will do it, just looks at all the idiots running stretched tires13.5" wide in 33 or 35 fall within recommended rim width range starting at 8.5" wide. So yes stock rins cannot accept this tite size.. I am thinking to put this size in my stock 22s. Also curious if anyone has tried.
See attached the recommended width of rim for all 13.5 is 8.5 min. Also these are from tire rack on cooper stt pro.I've never seen a 13.5 width tire that has listed 8.5 as minimum width for the wheel. Most start at 9.5 minimum, with some wanting 10" wide minimum. Your factory wheels are on my 9" wide. Any reputytire shop will not mount them to stock wheels. Of course you will find shops that will do it, just looks at all the idiots running stretched tires
I guess you can run them if you want. Other brands show different. I certainly wouldn't squeeze a 13.5" wide tire in a 9" wide wheel. You lose contact patch and will wear out center of tread firstSee attached the recommended width of rim for all 13.5 is 8.5 min. Also these are from tire rack on cooper stt pro.
All brands have same recommended rim width range, manufacturers put that in specifically as the ideal rim width. Yes you can run 13.5 on a 9" rim safely with normal wear.I guess you can run them if you want. Other brands show different. I certainly wouldn't squeeze a 13.5" wide tire in a 9" wide wheel. You lose contact patch and will wear out center of tread first
