Anyone running 35x13.5R20?
Jupiterak
I've got 33x12.5R20's but I'm due for a new set of tires. Just curious if anyone is running 13.5" wide tires on stock rims.
Do the tires you have now rub at all in the wheel well?
You do realize a 13.5 wide tire isn't meant for stock wheel width? Shoot, the rock wheels are still bare minimum width for 12.5s, and that depends on the tire manufacturer.
I know but just curious if anyone tried it
13.5" wide in 33 or 35 fall within recommended rim width range starting at 8.5" wide. So yes stock rins cannot accept this tite size.. I am thinking to put this size in my stock 22s. Also curious if anyone has tried.
I've never seen a 13.5 width tire that has listed 8.5 as minimum width for the wheel. Most start at 9.5 minimum, with some wanting 10" wide minimum. Your factory wheels are on my 9" wide. Any reputytire shop will not mount them to stock wheels. Of course you will find shops that will do it, just looks at all the idiots running stretched tires
See attached the recommended width of rim for all 13.5 is 8.5 min. Also these are from tire rack on cooper stt pro.
I guess you can run them if you want. Other brands show different. I certainly wouldn't squeeze a 13.5" wide tire in a 9" wide wheel. You lose contact patch and will wear out center of tread first
All brands have same recommended rim width range, manufacturers put that in specifically as the ideal rim width. Yes you can run 13.5 on a 9" rim safely with normal wear.
I'd want to try these on the stock 22s, just not sure of the fender rub and what spacer you'd need to pull them away from control arm
All brands do NOT have the same recommended rim width.
Some of those no name brands, like Nitto just for example. That's for the Recon Grappler and direct from Nitto website
Amazing. Well then op should consider the cooper stt pros for the stocks
