Fuel management delete
Djdrag
Try find something to delete the fuel management system every thing I have found is for GM only
You mean MDS? Is there a reason you want to delete it?
To properly delete it, you will need to replace the lifters, remove the MDS solenoids and install plugs, then get a custom tune for the computer.
If you just want to disable it, so it doesn't turn on, you can either hit the tow/haul button, use the gear limit switches and set it to 8th gear, or buy a Pulsar piggy back "tuner".
