Front Camera
kthibs22
Does anyone know if there is a setting to automatically turn on the front camera when parking?? I have the 360 camera and front/rear parking sensors. Currently I just go into Controls/Surround Camera manually when parking but wasn’t sure if it can be automatically be set to pop on.
Don’t think so. If you switch to reverse for a second and then back to forward it will show the front camera if you have the delay set in the system. I have also set the camera button as one of the buttons across the bottom of the screen so I can get to it easily.
You can add 360 camera icon to home screen.
Thank you, I will add the 360 camera icon to the bottom favorites.
Digging up old conversation. This thread was for the old Uconnect. Has anyone figured out a way to get the front camera or surround camera to turn on when the front park sensor alarms?
On UC5 and with a 2023 BCM you can have ParkSense Base Cameras activation.
Something I can do with JScan? Or via the uc5 settings?
2025 with 360 camera have parksense camera activation as an option in the Uconnect safety amd driving assistance options. I really like it and was told it is a new option based on the all new electrical architecture for the 2025. The only annoying thing is mine will randomly turn itself off every so often and I had to go back into the menu and select it again.
I’m in the same boat. Sometimes I’ll get that menu option to stay selected for the drive but after that it will turn itself off. At what point does the camera activate with the option selected? I turned it on and got the first line/warning from my forward park sense sensors in a drive thru but nothing happened.
Mine activated the front camera as soon as the front park sense sensors detect an object. I assume they are linked so the sensitivity is adjustable like the park sensor alerts.
