Cylinder Misfire Normal?
Any update to this issue/normal operation? Mines a 2019 and I have the same thing. I however, notice less misfires when I fuel up at gas stations that are not Costco.
Oddly enough I have a 2019 Ram 1500 5.7 with 57k miles. #8 fuel injector was replaced due to it causing a misfire. Dealership said there are misfires on all other cylinders but not enough to cause another CEL and suggested to add a fuel system cleaner in the tank. I normally add seafoam every so often. I put Costco gas almost exclusively in this truck. Is it the Costco gas causing this? A friend who is a service advisor at Lexus suggested me to not use Costco gas because his customers experience issues as well. Truck is still at shop but now debating if I should have all injectors replaced or try my luck with Berryman b12.
Costco is Top Tier Gas
This screenshot was after a 10-15 minute drive. I’ve been noticing some odd throttle issues from time to time as well as a rough idle. This past weekend the check engine light game on and I grabbed this screenshot. I tried swapping the ignition coil from cyl3, but no change. I took it in and two of the injectors were replaced. It’s running so much better now. I am going to avoid that cheap gas for now.
