I need to do this as my current one is leaking, what additional parts do i need like new clamps or seals or anything?I completed the swap, new Rebel/Bilstein dampers installed INSIDE the original factory airbags. It went much better than I pessimistically feared. View attachment 180391View attachment 180390
It appears that the Rebel shock extends another half inch in rebound.
Airbag disassembly requires patients and finesse. But it can be done without any beating and banging.
View attachment 180392View attachment 180393View attachment 180394
Many more insights to share if anyone is interested.
Ok I’ll see if I can get them to work. I know the 5100 is more “aggressive “ over the other and more compatible with lift and larger tires which I am running both of those. (35’s and level links 4 corners)I went with the 4600 series but the part I purchased and have been running now for 20k miles or more, (said the same thing about not working with air suspension), has been working just fine. There might be some sort of subtle valving difference but I can't tell the difference if there is. I've been tempted to order the correct ones just to see if the difference would be noticeable.
My thought is the air ride shocks must have some sort of balancing circuit where they shift fluid from one side of the plunger to the other to balance out for ride height. Basis for this thinking is that when you remove a shock, they typically want to extend to their max. Several people have now commented that when they removed the shocks from an air ride suspension, the shocks want to retract to a spot 2-4" from full extension. But, a couple days later, they are at full extension and react as expected.
I think someone here said up to 5 times of disconnecting is okay. You should put it on exit mode to conserve as much as you can though.I’m new on here, and I want to do the oem strut(68323489AD) swap for the front air suspension. I have read the entire thread maybe I missed it, but when installing the air bag assembly back together into the truck, do I need to recharge the air system with nitrogen? Or is it just as simple as connecting the bags and letting the truck fill them up with air?
I don’t know if I’m overthinking it, because I have never heard of nitrogen going back into an air system suspension. But just want to make sure I don’t ruin my air suspension.
Thank you everyone for this information, very informative, good to know there’s DIY-ers around.
Thank you for sharing this. I will be taking on this job to replace my front struts over the next few weeksI completed the swap, new Rebel/Bilstein dampers installed INSIDE the original factory airbags. It went much better than I pessimistically feared. View attachment 180391View attachment 180390
Have you done this yet? I'm thinking I might also try this.Thank you for sharing this. I will be taking on this job to replace my front struts over the next few weeks
Pretty sure alfa OBD has the ability to pump down the bags without dumping all the gas. What are your plans for recharging the vented nitrogen?So... I just finished the strut/shock swap on my 2019 Limited. It wasn't as easy as I had hoped... 3 trips to the store for tools (mostly open-end wrenches at the larger metric sizes... and a fitting to use with my air compressor to reseat the bag on the strut after reassembly). I started on the front driver's side... and really struggled to get the shock out... turns out it was still pressurized. I disconnected the 12mm fitting from the top of the strut where the air line was and heard the air escape... but when I removed the other brass fitting, much more air came out. Then there was the dreaded retainer ring at the top... not terrible to get out... very terrible to put back in. I ended up using a bottle jack as a make-shift hydraulic press to put it back in. I also really struggled to separate the air bag from factory strut. Lots of learning occurred on the driver's side, and the passenger side only took me about an hour. I waited until the long weekend to give myself plenty of time to do the work and make runs for tools... took me about 24hours total to do both front and back including sleep, breaks for food/drink, and trips to the stores. Phew... Its Miller Time.
