HOW TO: Add Digital Rearview Mirror
Here are the instructions for installing the digital rearview mirror in the RAM.
Part List:
Mirror with 1 Video Input Channel, no FCW or ACC - 68448639AB
Mirror with 1 Video Input Channel, with FCW or ACC - 68448641AB
Mirror with 2 Video Input Channel, no FCW or ACC - 68519111AA
Mirror with 2 Video Input Channel, with FCW or ACC - 68519222AA
Center high mounted stop lamp with camera - 68551077AB
10' Fakra Z - Female to Female
Amazon.com[/TD]
Parts if you have a 2019/2020:
2021+ BCM - 68496414AD
Wiring Harness from Jimmy07
You only need one of the mirrors. Just choose the one that fits your vehicle and if you want to have 2 inputs or not. You only need the 2 inputs if you plan on adding another camera like cargo, trailer, etc. For the 2019/2020 you will need a 2021+ BCM and the wiring harness from Jimmy07. You can get a used one from a junkyard. You can then stash this under the driver's side dash or the front seats.
Installation is fairly simple. Replace the CHMSL with the new one. Run the cable in the headliner from it to the mirror. Replace the mirror with the new one. Connect the mirror, truck and BCM using the wiring harness. Start the truck and enjoy your new mirror.
2019/2020s will lose auto dimming side mirrors. You can swap your BCM for a later new one (not used), but you would need the dealer to restore your configuration. If you swap it yourself, you'd need to do it at the dealer because it won't work right until the restore is done.
For 2021+, use AlfaOBD to set the following settings for auto dim mirrors to work.
LIN & Misc: CRVMM Present to NO
CBC Config I/O Usage: RVDM Present to YES
Part List:
Amazon.com[/TD]
I have a 2026 trying to add digital rear view mirror. What is everyone using I installed camera and mirror and still not working. Thinking 26 has 2 mirror modules I’m getting a lossof
Communication with module A
Probably not going to happen. No one has figured out how to add stuff to the 2025+ vehicles because of the new canbus architecture. There is no way to make changes to the BCM which might be required.
The parts you have are for 2025 or try to put a 21-24 mirror. The only mirror that requires a module is the 3.0 of 2500 3500
The Mirror I have is from a 24 added the sales code to the BCM GRGP that’s why I’m seeing the loss of communication code thinking I need to try a 25-26 mirror
How were you able to add the sales code on 26 BCM? Did dealer do it?
Also the 25+ might be using the newer mirror and the module its complaining about could be the mirror processor. Basically that is like a hub that sits in between mirror and camera and lets you plug in multiple mirrors from trailers, side mirrors etc…
Whats the mirror and camera part number you have installed?
It's probably the mirror because I also wanted to try a digital mirror on a 2022 Jeep Wagoner and it didn't do anything, but since 2021, the Jeep Grand Cherokee and Wagoner had the new Atlantis High system, and I imagine they have to look for that CAN signal.
Looking to tackle this on my 24 3500. Has the surround cameras with ACC and the FCC. Is there an exact parts list floating around some where in the threads?
-Thanks
-Thanks
Did you look at the 2nd post?
-Thanks
-Thanks
For the years 23-24 only 3.0 digital mirrors came out, even in 2025, but I still believe that the 21-22 model will work in 23-24.
I have a mirror and CHMSL for sale in the for sale thread if anyone is looking to save some $$ on this easy upgrade.
Hey all. I wired up the mirror and brake light cam today and have the 24 foot R58 fakra female cable coiled up in the back bumper. Does anyone know what kind of plug the trailer camera kit uses to plug in? It looks like a kind of typical coax connector but I don't have space on the bumper where I can install it so I'm trying to just buy an adapter to fabricate something smaller but don't know what kind of connection it is.
Did you ever figure this out?
I'm also looking to install a second camera on the back of my trailer.
I have a 2019 RAM 1500. I purchased the 2-video input mirror 68519222AA I also have the white 6" adapter for the Mirror power.
The truck originally has an auto dimming mirror.
DO I still need to add a BCM for this to work. Was under the impression the little white jumper replaces the need for that now.
I could not get any of the OEM camera modules I had to work, I.E. Front Grill camera, or spare Tailgate handle camera or trailer add on camera. All I get is the video not present Icon on the mirror.
I understand the Black Fahkra connector is for the CHSML camera and the White Fahkra is for secondary input?
Do Both cameras nee
d to be the 68448640AA?
Do Both cameras nee
It's in the first post, you need the BCM. Where do you see that the white jumper cable replaces that? Also the camera for the digital rear view mirror is not the same as the other cameras in the tailgate or anywhere else.
I was given an adapter like this one in the picture and told that was all that was needed.
Not
Just an FYI to those with extended warranty and no DRVM, wanting to do this modification.
Beware when you come in to do warranty work, the dealership will bother about it. Both of my rear TPMS started being faulty, and they basically interrogated me about the DRVM and 3rd brake light. Held my ground and said this is how it came when I bought it used. Below is proof of my modifications, will keep you guys updated if my warranty work gets approved.
(Im probably a low IQ person, for not knowing this may void my warranty. Also I never mentioned of doing any modifications)
img_4406-jpeg.206437
It won't void your warranty unless they can prove what you did caused the issue. They will try, but they have no legal standing.
Yep, you called it! They tried it, warranty got approved in the end after some time. But definitely grimy how the dealership was trying to void my warranty off some simple parts that are OEM.
To those that end up in my position, in the future, hold your ground
Well, I installed the mirror (68519222AA) the other day in my 2019 DT and made a bracket to mount the camera (68448640AA) on the rear glass of my Leer Topper.
I can plug into the existing harness for my Dimming Mirror with Auto High beams and the Mirror powers on properly with the key. I Also used the dongle I showed earlier and it works fine too.
So, my question is what am I missing by not using the BCM?
I did run into cable length issues using RG174. After about 20 feet or so the signal loss kicks off the camera. I think I may make a RG314 and see if it is better.
This is concerning since the second input for the trailer I ran to the rear as well and I'm assuming that if I add additional cable for the length of the trailer It'll drop the signal due to loss.
