Mirowpl
Is it me? I can’t find a setting to change it. It has been like this on my past 3 ram trucks.
Thanks
Thanks
The first part of your explanation does not explain the second part.Stellantis found 31 (32 levels, as 0-31) was too granular, steps for volume change were too big. The next digital choice (adding one more "bit" in base 2) is 63 (0-64) and this was too many levels. Users could not tell a difference between two values, and a control with that fine a resolution required too much spinning due to limits in cost-effective reliable miniaturization.
In testing, setting the control to go from 0-38 (39 levels) was the optimal balance of volume change and knob spinning.
Each "click" of the knob is a noticeable but not too big change in volume, yet not too many clicks from silent to max. Back when I learned electronics the first time, this was easily managed in the analog domain. Today, the tech is all digitally encoded.The first part of your explanation does not explain the second part.
Highway driving with windows down im at 38. Sounds great. Factory front door speakers actually sound really good. 3.5” have all been replaced Buying some Alpines 6.5” to test sound quality for the front doorsare we ever turning up the volume that high?? 31-35 is my max after that it's distorted.
Mine goes to 12. I measured.Mine goes to “11”. It’s one louder!
Sorry, couldn’t resist.
i tried several set's of 6.5's with a 6x9 to 6.5 adaptor. if i could be so bold as to make a recommendation just throw a good set of 6x9's in the door/doors.Highway driving with windows down im at 38. Sounds great. Factory front door speakers actually sound really good. 3.5” have all been replaced Buying some Alpines 6.5” to test sound quality for the front doors
Mine goes to 12. I measured.![]()
Crutchfield says they dont fit..i have a 2022 1500. 12” and Alpine sound system. I’ll call them and see what they say. Thanks for the recommendation.i tried several set's of 6.5's with a 6x9 to 6.5 adaptor. if i could be so bold as to make a recommendation just throw a good set of 6x9's in the door/doors.
it sounds crazy but power bass makes factory replacement' with duel voice coils or get some CDT audios
shows a 4th gen but it fits a 5th
or
