Best Oil for Hemi "Tick"
I have had a few 5.7s, older 05 gen Durango, sold it with 185,000 miles, a 13 Ram 5.7 traded it in with 125k, now my current 21 bighorn 5.7. Never had the Hemi tick in any, just manifold bolts broke and were replaced. I only use PUP and 8oz of lubeguard biotech moly enhancer, in bigger bottle they call it lubeguard heavy duty. Pup was just on sale for $20 a jug too, so bought 6, cant beat that deal. The lubeguard is only engine additive I will use. I do use fuel injector cleaner (has to have PEA) additive to gas regularly and feel improvement after a tank, I double dose the recommended amount once a year in tank. I change my oil at 8k miles, so for me is about once a year and always used Puraltor boss 20k oil filters. I have run the valvoline restore and protect in other vehicles and my riding 26hp lawnmower, if I ran it in my hemi, I would run it like 4k miles to clean up engine, then go back to the pup and lubeguard.
Today I had my oil changed, at the dealer, for my "Love Machine" RAM 1500 with the 5.7 hemi. When I was all done service advisor at first told me they put in a semi-synthetic then quickly said, oh they have a different gun back there so you did get the Full Synthetic oil. But I wonder......... so I think I'm going to change my oil somewhere different next time, and I thought if it does have semi-synthetic, then why not change oil at let's say every 4,000 miles. That would be a good idea regardless of what oil goes in, right? My 2021 RAM calls for 5-20 grade oil and after reading everybody's thoughts, I really don't know what to think. My mileage is only 60,000 right now and I've got the low gear ratio so I'm getting higher RPMs then the normal RAM driver with the "normal" rear end. I live in Colorado, so yeah it gets cold in the winter but I also take long trips to Oklahoma and Texas on business. I'm still thinking go with 5-20 but what are your thoughts for my situation? Thank guys, and I'm brand new here on the forum.
I say don't over think it. Use what you feel comfortable with. I use 5w-30 in all my cars that ask for 5w-20. But honestly, as long as you change the oil at the correct intervals you will be fine. And there is nothing wrong with following the recommended 5w-20 if that's what keeps things in your comfort zone. Also, if they put in semi synthetic oil, I wouldn't sweat about that either. Years ago with my first 4th gen 1500 with the same 5.7 hemi available today, the dealer would use dino oil. I never had issues with that truck either.
Is there a generally regarded "best" oil for the 5.7 engines? I know for Audi you should run (not walk) from what the dealer's use and only ever use Motul 8100, amazing oil that's also cheaper than the more well marketed brands. Anyways, any pro star hemi heads out there that swear by a particular brand and grade of oil? I heard going thicker viscosity is the answer, but I really don't agree with that. Don't you just want a "better" oil that's the right grade that Ram says to use so that it can get up into the roller pins?
Honestly I have never had a tick in my 22, 5.7L, and I use 0-20 Napa brand full synthetic.
I have ran Penzoil Ultra Platiunum 5w20 for years and it’s the best shelf oil I’ve found. Project farm is a great source for reviewing oil tests and the only oil to beat it was Amsoil and it just barely beat PUP. Only oil I’d recommend over Penzoil would be Amsoil as I already know that oil is top tier from my motorcycle racing days. Redline is overhyped and royal purple sold out and use a different formulation from what I’ve heard. This is coming from a long time hemi owner who has never had an engine failure of any kind. Oil changes every 3k miles no matter what anyone says. 👍
Penzoil Premium is fantastic oil, fully agree! I also run 5w/20 and change every 9-10k. Next test with 140k
HEMI tick has extremely low rate on 5th Gen RAM, nothing to worry about!
I’ve had the tick quiet down by using a thicker, high‑quality synthetic and sticking to shorter change intervals. Warm climates usually benefit from a slightly higher viscosity during hot months.
Redline 5w-30 is a good choice, but RL is no longer the favourite. Seems that HPL is the new best-in-class oil to beat and its priced accordingly. You can probably run the standard PCMO but if you want even more protection and runtime then the "premium plus" or "no vii" or "supercar" flavours will do that for you. There is an experiment on BITOG right now where one member has run HPL for 30,000 miles to date, all backed by UOA's and pics of the interior of the engine (which is a 3.6 pentastar), it is completely spotless in there which shows the incredible cleaning performance of all HPL's oils.
I'd also suggest a 0w-30 or 5w-30, the 20 weight is there for fuel efficiency gains only, not protection.
Sute wish I knew all the acronyms!
RL = Redline (oil manufacturer)
HPL = HP Lubricants (oil manufacturer, sold online at advlubrication.com)
PCMO = Passenger Car Motor Oil
BITOG = Bob is the oil guy (motor oil forum)
UOA = Used oil analysis
no vii = no viscosity index improver's (thickeners to make thin oil thick at operating temps)
