Wireless Charging Kit with Cubby
I found a couple of more things I will need to complete this project. First, beyond the two screws mentioned, I will need two U-clips (speed nuts) and two smaller screws. I got the U-clips at Lowes $1.66 for the pair. The smaller Mopar screws come from my bolt drawer.
The second one is more costly. I got to looking at the three holes in the bottom of the cubby and began wondering if there is supposed to be a rubber mat that goes inside it. Turns out that there is. And unfortunately, it costs about twice what the cubby itself does. But hey, it's for my sweetie and I want everything to be perfect. Mopar part number is 68524508AA.
Quick question. Do I have to get the dealer to program this into the system? I didn't see that anywhere in the online examples, but it is in the directions that came with.
Never mind. Like everyone else, mine works fine without the DealerCONNECT flash to put in the sales code. It simply wasn't working because I had the doors open on the truck. Turns out, they have to be closed for the charger to come on. 🥴
I'm picking up a 2023 Ram Rebel 2500 this week. Has anyone added the OEM wireless charger? The dealership said that they don't have the code to do it on the Rebel.
Was gonna send you over to the 2500 forum, but looks like you already made your way there and got some help. 👍
Finally, I got the "Ramcharger" parts for my sweetie's truck, today. The original online Mopar company I bought from turned out to be slower than Christmas. When I called them last week, 13 days after I made the order, they told me they weren't sure if they could even get the charger. :cautious: So I asked them to cancel my order and they did. I reordered from Word Parts Direct. That's who I have ordered from before. It's the online parts department at a dealership in Garland, TX. They have excellent customer service and checked with the warehouse before they made my order. Got my parts ONLY FIVE DAYS LATER. But the cost was higher. Here's the breakdown:
Everything I need appears to be there, except as mentioned already, I need two screws to secure the cubby.
Luckily, my "bolt drawer" is full of Mopar screws and bolts. So I found these two that worked great.
I will try to post some more photos of the actual install. I figure that will happen next weekend. But we will have to see. ;)
Will both sides accept a charging module? If so, did you install two? Can I just parallel the wires and have 2 wireless chargers.
This one is only made to accept a single charging module. The one that has two is a different part number.
Wish I would have seen your post earlier. Thought I was smart and bought a dual console panel and a charging module last week. Planned to buy a second module if the 1st one fit. Much cheaper that the kit. Now that I've received them, I see the module will not fit. Thought I was really smart and could remove the plastic housing from the module and make it fit. NO!
Can you post a pic of the back side of the front panel; especially the module mounting area? With and without the module installed, if you can. The front panel I have looks the same as yours; except the icon and "WIRELESS CHARGER" are imprinted on both pads. I have the same module as you. Seems like I should be able to modify the back of my panel to accept the module. Thanks, Brent
For anyone that added this, what did you have to code for it to work?
I found out from Jimmy07 that the 2025 charging modules won't work with 24 and earlier trucks. I gave up on trying to add the dual chargers. Decided to roll my own. DO NOT TRY THIS AT HOME. Turned out to be a PITA. I should have bought the correct panel. I seperated the "phone pad" from the panel. Sawed out an oppening big enough for the charger module. Made an impression of the LED to cut the hole for it in the phone pad. It's a half moon hole, so I used a half round file. Took foreven and I still missed the location. Had to build posts for the screws to hold the charging module. Although the panels were originally heat riveted together, I reattached with screws.
Anyway, it works.
Anyway, it works.
Now I find out that the red blinking LED indicates it's not charging. I've read posts about finding the sweet spot for the phone; but there's no sweet spot that changes the LED from binking red to blue. ??
I changed only one setting. Not exact wording; but something like LIN BUS active for Wireless Charger. (just type Wireless in the search bar) After I changed that setting, I got the flashing red LED and thought I was done. But, it isn't working. When the phone is actually charging,the LED changes to blue. Don't know if I missed a setting; or if something else is wrong.
Well, stupid me. Researched my Samsung A16 and found out it's not capable to charge wirelessly. Tried my neighbor's iPhone something (which he wireless charges in his car) and still get only the flashing red LED.
The charger does not work with any of the doors open. Silly, but you have to close the doors to get it to show blue and charging. Other weird detail is the phone “sweet spot” is not lined up with the cord opening. So on the wired CarPlay trucks, it won’t set in the charging dock and allow the cord to be plugged into the phone.
Thanks. I was aware of the doors closed operation. I moved the iPhone all around looking for the sweet spot. Pretty sure either I got a bad charging module; or there's some type of conductive material built into the plastic 'phone pad" that's not in mine. I modified my standard phone pad to accept the charging module. I've confirmed continuity of the LINBUS wire from the BCM to the charging module and that I have a good ground.
Just tried it with a Google Pixel and a Samsung S21. Charges (blue light) both. Still using my standard "phone pad" that I modified to accept the charging module. So, it appears there's no extra or conductive material built in to the Ram Charger phone pads.
