3.5" RC M1 Lift installed!
firemedic10584
Central Florida
Finally got my truck finished up a few days ago. Went from the Bilstein 5100s with factory 22" wheels and 305/45/22 tires to the RC 3.5" M1 lift kit with aftermarket wheels and 35x12.5 Ridge Graps. What a difference! I feel like it's the perfect stance for a pavement queen.
Specs -
Lift - 3.5" RC M1 lift with 2" rear coil spring spacer (don't do the supplied 1" spacer, your truck won't sit level still and be nose high. Ask me how I know)
Wheels - 20x9 GFX wheels with a 0 offset.
Tires - Nitto Ridge Graps 35x12.5.x20
I had very minimal rub on my RC mudflap in the front and the factory little mudflap. I did also trim a small section off the bottom of the wheel liner in the front, then zip tied back the inner corner. I have zero rub no in any direction, forward or reverse. I also changed my tire size with Alfa so my speedometer and shift points are accurate. Let me know what yall think!
I also will add, when doing the lift, I discovered my passenger side tie rod outer end, the ball joint boot was split. Before doing the lift and getting the new wheels/tires, I was battling a pull to the right even with my shop confirming my alignment was in spec. I have no idea if that had anything to do with it, but my pull is now gone. I of course did get another alignment once all this was done, but whatever it was, is gone now. I also was still battling the famous "clunk" even after changing out multiple parts. It wasn't consistent, but it was still there. After installing this kit, I can not get the clunk to reproduce and going over the same speed bumps that would once cause my clunk, is now smooth. So, I also don't know if my Bilsteins and stock UCAs were the culprit of the clunk sound, but that issue seems to have been resolved now too.
looks great, beautiful truck.
What was it that drove you away from the Bilstein to begin with, just the ride height?
Asking b/c I'm trying to decide what direction to go with leveling and/or lift. guidance on these things is all over the map, seems to be minimal consensus.
I was wanting a big more of an aggressive stance, while still not being over the top for a daily driver. I think the 3.5" kit paired with 35s is the perfect happy medium looks wise and daily drivability wise.
I have the same kit and I’m currently looking for a shop to have them installed. Where did you get yours installed at?
I just got the 3.5" Readylift installed with 35x11.5x20 Nitto Recon Grapplers. Very pleased with how it looks.
I did it myself. It's pretty straight forward if you're comfortable turning wrenches.
Any issues with the RC lift so far? Looking at the 3.5 RC with M1 as I plan to do some offroading, but see that many people are having issues. RC is more in my price range, or I would opt for ReadyLift.
I had no issues while I had the truck. I sold the truck a few months after putting the lift on. But, it drove just fine for being a pavement queen.
