The Fibrenew guys are usually a bit closer than that on matching texture. But it’s still better than a cracked or gaping hole in the seat.
I had some badly chaffed vinyl on a boat once and he didn’t have an exact match to the texture, so he made one by imprinting the vinyl in a good area. It was pretty much a flawless fix when he was done and matching airbrushed color. Like anything, not all techs are created equal.
Looking closer at the picture, I think I'm going to have to have him come back. Looks like the texture patch he put on in first picture isn't clocked properly to line up with what's on the seat.
Had a tonneau cover installed today. Kind of a weird fit because of the silver rails but I still like it.
Drive home and about 20 minutes later the truck alarm starts going off. Go out, turn it off and relock it. Come back in the house and it goes off again. Go back out and unlock it but this time open and close the tailgate, just in case it was because of the install. So far so good.
Anyone else experience the alarm going off for no apparent reason?
Maybe the sensor’s getting squished or covered up
That’s what I thought. Looks to be about 30 degrees off pattern.
I took the truck in for the last oil change under drive train warranty.
I have another 8k km to go under warranty so I'm crossing my fingers that anything that is gonna break chooses to do so within that window. 🫤
Had a set of Bilstein 5100's installed on the front end.
I allso had the tranny serviced @67,400 or so miles on it.
Should be at about stock height when I tow our TT using the Anderson hitch.
