Please post your Tire and Loading sticker
The PSI is also tire dependent, which changes with trim and even years, so that obviously is what those tires on that GVWR vehicle require. OEM works in conjunction with tire mfrs to determine the proper PSI, just ask Firestone! You ought to see the Rebel and TRX PSI. I go lower than my sticker sometimes empty just for a better ride. There has been posted an online calculator when you change tire ratings as well.
2023 Big Horn with the tow package.
my guess is 1480#
I'll take a guess at 1,625. I hope they actually build it.
21 bighorn quad cab level 2 4x4 3:92, tow package,
Here's the stickers on my 2020 Ram 1500 Limited 4x4 5.7 HEMI eTorque 3.92, Crew Cab, 5'7 Bed. Disappointed on how low the payload is at 1252lbs. I was blinded by the luxury options and now that I'm in the market for a TT, I feel super "limited" on size/options. lol
Same here, I actually have a lower payload, but I still found a 32' TT that I can tow (empty tanks and nothing in the truck aside from me, my wife and daughter) with a WD hitch. One thing about the air suspension, do never have to worry about overloading it, as it will tell you if it is too heavy lol.
Ok I'm having trouble reading this. So on @Ramit392 's post it seems that the max tow is 7100 lbs? Is that right? Asking because I'm just inexperienced at reading these.
From looking at Ram's chart here: 1756224430334.png
It appears for my configuration the max tow is 8240 lbs.
7100 is The GVWR Gross Vehicle Weight Rating. So, how much the truck can weigh completely loaded with passengers and gear.
Has nothing to do with towing. However, it is involved with figuring out how much you can tow.
Wow!! I cant read this!! I will repost.
Honestly, I’m impressed the Tungsten carries a 4-figure payload, and not just barely either. Bravo!
Wonder what the full weight of Hemi + eTorque was? Quite a pig.
From looking at Ram's chart here: View attachment 204922
You can look up the specifics for your VIN. Plug it in to this link (replacing the VIN that's already there).
