jl13
- May 28, 2021
- Location
- boyle heights, CA
Tighten the end link more to compress the bushingsEmpty oil catch can
Rotated tires
Found the bushings on the driver side suspension max swaybar end link to be spining freely. The link itself is tight and not loose just the bushings
Any body else with these have seen this
ive had mine go loose after initial installation, went back made them tight and have been good since.Empty oil catch can
Rotated tires
Same hereive had mine go loose after initial installation, went back made them tight and have been good since.
WHERE DID U BUY THAT AT?Fixed the issue of slipping on White Knuckle rock sliders when it's wet:
View attachment 203557View attachment 203558View attachment 203559
went with topo print. I have enough material to do the whole outside tube but decided to only apply to spots where I actually step on.
amazon. skateboard tape.WHERE DID U BUY THAT AT?
which one?Wait, something is wrong here. Those have paint left on them.
which one?
