Preferred Fuel System Treatment?
Which do you prefer?
  • Lucas Oil Fuel System Treatment
    Votes: 5 45.5%
  • Chevron Techron Fuel System Treatment
    Votes: 3 27.3%
  • Seafoam Fuel System Treatment
    Votes: 3 27.3%
  • Total voters
    11
  • This poll will close: .
Squatch79
Bankhead National Forest, North AL
I've been noticing some rough idle and decreased performance. Currently have 92k on the odometer and have been thinking about running a fuel system treatment on my next fill up to see if that helps
  • Like
Reactions: RHO
Ever replaced the spark plugs or cleaned the MAP sensors? I’d start there and see.
If you’ve been using top tier fuel there isn’t much more a little bottle of additive can do other than relieve you of a few bucks.
I have had 4 Hemi vehicles, fuel cleaner made difference on my vehicle's. My 13 Ram 5.7 every year I when tank was about 25 gallons I would put a double dose of a p.e.a cleaner like Regane, then at same time add double dose of lucas fuel additive. When I got down to about empty I could start feeling engine get power back and smoother. Seemed like the power coming back happened all of sudden. Is only additives I use except lubeguard biotec/heavy duty in my oil to increase moly in the penz ultra plat.
I use redline. Spring and fall tank in the boats and every 10k miles in the cars. I plan a treatment when I know I’m going to blast through an entire tank I.E. towing for more than 3 hours.
Have done that in all my 5.7s to well over 100k with 0 fuel system related problems.
I’m also by the book or sooner on other maintenance like plugs/filters/pcv/TB cleaning etc.
Try cleaning the throttle body to smooth out the idle.
Don't just hose it down with carb spray and don't use a wire brush. Too much spray and you run the risk of it getting into the throttle position sensor and motor. A brush may scratch things. Just wet a rag and scrub the edges of the throttle plate and the throttle bore where the plate closes.
If it was really gunky, the idle may be high afterwards, but it will relearn soon enough.
put the additive in when you are down between 1/2 and 1/4 tank maximum treatment. that way you are not mixing 1 bottle with 25 gallons of gas ,
Read the bottle, it should give you a range of how much dilution is recommended.
I can't imagine the cleaner works better at higher concentration over a shorter duration than it does with more dilution and more time.
Also, not sure if higher concentration could negatively effect timing, cylinder temp, spark plugs, knock, O2 readings, or catalyst materials.
Diesel extreme for the diesel dudes or gasoline extreme by hot shots. Both have worked magic on my Eco and motorcycles.
I never had a issue adding double dose of fuel system cleaner. Make sure it has p.e.a on label. Forgot, but post above is correct, clean that throttle body about every 20k Miles, does smooth out idle and is 15 minutes to do and easy. I use Rislone hy-per or gumout expert for injectors.
