anonymous63081
- Jan 2, 2024
Double check the build sheets Anthony provided at the beginning of this thread. The new colors are available on the Limited and Tungsten trims (excluding Canyon Lake on Tungsten).It’s usually a month or two behind when the ordering starts for the next year model. Only trouble with those nice new colors, they are really only for Laramie and below. And if you want the Rambox option ( automatically on Tungstens ) that also restricts what colors you can opt for.
From what I saw, there are no new colors that I could order. I usually have the Limited ( which I believe is gone for’26, it’s now the Longhorn, then the Tungsten.
As far as the Limited/Longhorn - it's basically the Longhorn that is "gone" not the Limited. While still available, it's no longer a separate trim but an optional package for the Limited as they have the same model code. I think the only difference is you get the bison brown interior and Longhorn badging while being restricted against other options (no Night Edition on the Longhorn, for example). I believe this change happened for the 2025 MY as prior years they were separate trims with more differences in standard features.
