Bedlight Help
jsl77
Did the bedlight install with the jumper wire. Need help with alfaobd activation.
What help you need? Could you provide more info? Plus, I don't think it needs activating?
Light not working not sure where to go in alfa obd. Unplugged the two plugs to see if there were already wired pinned in the spots and I now have no interior light and service start/ stop and traction control lights on.
Light not working not sure where to go in alfa obd. Unplugged the two plugs to see if there were already wired pinned in the spots and I now have no interior light and service start/ stop and traction control lights. Not sure what i did or bumped.
  • CBC Config I/0 Bed Light Switch Input
    Present - Pin G16: -> Yes
  • CBC Config 1/0 Connector F Pin 6:
    Baggage Compartment Lamps Output
    Present -> Yes
  • 2014 CBC Config 1/0 & FEAT.: Bed Lighting
    Present - Pin A5: -> Yes
    Present -> Yes
    Present -> Yes
Is there away to reset to factory and start over incase I do something wrong.
No. You need to backup your configuration first. You can restore it if you screw something up.
Well I didn't make any changes yet. Just look around. Not sure why I'm having the different service lights come on unless I knocked something loosi g under the dash.
Shouldn't have any issues after installing it. You must have messed up a wire or something. You didn't explain what method you used? Did you install the dealer upgrade kit or do it a different way?
Used the oem kit with the bypass cable. I did not run a new wire to the front. I have wires already pinned to the locations used for factory set so I figured the wiring was already there.
Got the other issues figured out. Had a loose plug.
    Present -> Yes
Thank, and one more question. Is there some where to see how to save current configuration as a back up and to navigate to the above settings. Again sorry new at this.
    Present -> Yes
