Canada/USA Imported Ram in UAE
Do you have UC5 or 2022 model? I have tested it on it only and believe it won't work on UC 4 or earlier model
Hi guys I have the same problem here in kuwait I have the ram sport 2022 from Canada and the navy system and the radio is not working 😕 I tried so many things but still it's the same
Can smoe one help
I want to update the screen and the system I have the 12 inch 5 gen screen
Thnx
So after being challenged by two mirrors of tow mirror. I got them changed to one. However I did lose ability of getting orange light of blind spot warning. Glass is 4mm which is thicker than factory ones which I think are 1.8 to 2mm. I think I probably have to itch out mirror back side lining. Any other ideas?
You can try, any case it's under warranty so why not ask them to bring it up to latest level. I would argue they should have updated maps and firmware before delivery just to get it done.
Yes, I guess itching is needed for LED. See my Limited GCC side view mirrors:
Thanks, these mirrors only are readily available but are smaller than tow mirrors so not one to one replacement. Only option to get them is to replace complete side mirror assembly which has It's own challenges. Plus I would have to spend a lot time in Sharjah scrap yards to get the same bells and whistles side mirrors that match my current ones.
I downloaded the latest maps, formatted usb to ntfs and it starts without any issues. Rather than just doing quick format to ntfs I did the long one. Process works with out issue
Please keep your USB for me 😅, i am not sure why it is not working for me. I have tried again today to format the USB without the fast format and chose the ntfs format but still the update it not starting. The more im failing to update it the more this itch is bothering me
hi dear
File size is 16.4 gig and one extracted it comes to many file
Just wondering if this correct
Appreciated
Perform at your own risk. Here is perhaps quicker and zero cost way to update the navigation to GCC maps on imported RAM. Maps across Stellantis are from TomTom. Goto web site
1. https://stellantis.navshop.com/#/downloads
2. On drop down menu select Jeep > Grand Cherokee > UC5
3. Select ASIA PACIFIC for map download.
Download all the files, unzip on usb and update maps. Canada/USA maps wont get deleted, new maps will be added.
after starting the upgrade it storage is full
how can clear storage
No clue buddy, if you find one post it here. Someone might get benefit
First a big thank you for all the help this is really wonderful and a big help. Let us split these two things so we can have the right steps and pin them so others can benefit.
We know there is a procedure for UC5(U Connect 5) that was released from mid of 2022 and this works by downloading the Asia pacific map from Stellantis website but this procedure will keep the USA/Canada maps and might not have enough space to accommodate the new maps. Can we get confirmation for someone who tried to reset the screen? I bought a screen with a module from the USA to upgrade my old screen I will try this procedure and see if it works. There are companies that take your module and update it for a big price so you can have both the navigation and radio working but it costs around 2200 dirhams.
For the radio I did not have anyone have a straightforward way to change into our frequency other then sending it to expensive programmers if there is please share. Thank you all
I dont have info about clearing space. But for frequency if you have alfaobd, bypass cable and vgate mclinker it's a five minute work. I have 2022 limited and have done it.
That is great I think my brother have the obd connection and cable but I dont have the software. What are the coding steps if you can share
Sent from my SM-S928B using Tapatalk
You would need alfaobd software along with vague mclinker obd. There is ton of info on the forum regarding using alfaobd, security bypass cable and alfaobd. Not every obd interface will work. I have shared in this thread, first page changes that are needed. These are running on my truck.
