map246
- May 27, 2025
I have had my truck for about a month. Everything has been great. No issues whatsoever.
Drove it yesterday morning and parked it in my driveway. Went out a couple hours later to leave and no start. I pushed the button and just ONE single CLICK. Everything inside (electronics) is working properly. I plugged in my OBDII and it is not showing any codes.
83k on the truck, battery date of manufacture shows 07/2022.
Based on what I have been able to find online and in these forums, it is most likely the battery, starter, or starter relay. I started with the easiest and changed the relay....no change. I took the battery to get it checked. Showed to be a "good battery" at 12.2V. This is a little low, but still should be enough to fire it up. I am having my son-in-law change the starter this afternoon. I am trying to avoid the tow and trip to the shop.
Without going down the rabbit hole of all the obscure things it could be, am I missing any more common causes here? Both keys are working, so its not the RF hub.
Should I change out the battery while I am at it? I have a connection that can get a battery for about $125.
