Out with the blue, in with the carbon fiber on my Night edition. Loved the blue, just thought it was a little too much for a Night edition Ram. Having solid black truck, it can almost be a little too much black. I wanted it to stand out a little more with some high lights. Give me y’all’s thoughts
Now do these: 2019-2024 Ram 1500 Led Taillight Tint Overlays
Pulled the trigger on som Katzkin leather seats to replace my factory cloth. I traded my 2019 Laramie for a newer big horn night edition in red. This is a pic from when I picked it up from the upholstery shop. My daughter obviously had to get her attention fill in it. The last few days it’s baked in the sun and all the creases and loose sections are completely tight now, which the shop told me it would. Very happy with the way they turned out! $2200 which included install for my set up. It’s less if you opt for the standard inserts. I went with diamond inserts and retained the factory heated seats. It’s an additional $750 per seat (as of now) if you want the AC option but disables your factory controls.
If anyone else is curious or thinking about going this route, I’d recommend calling a nearby authorized Katzkin installer before ordering from Katzkin if you have one near you. The shop told me they have samples of all options. Also, if I’d ordered thru them, the price would’ve been less and all warranty claims would be done thru them as well, vs dealing with Katzkin customer care. Which isn’t bad but local would be easier. Overall, very simple process when ordering direct from Katzkin and would definitely recommend!View attachment 201684
As a Gator, I cannot condone red and black, but that looks good and kudos on being bold. All black interiors are too common.
How long does the tire coating last for you?
Not sure, the last time I used it I only had those tires for 5 months after applying it. It was still looking good. All in the prep work and not hitting it with tire cleaner, just mild soap and water after it is applied.
Watched camp while my friends went scaling boulders.
Also, Happy Flag Day.
