2025 Ram Laramie Front Tow Hooks
RogerO
Hello All: Looking for advice here. Love my flame red beige tan salt interior. New engine 3.0 SO and torque are fab. Can’t seem to find tow hooks on line that fit. Any help is appreciated. Roger O
I went with crinkle black finish. It says in the description that it fits 2019-2023 but if you cross part numbers to the mopar catalog, they fit. The install is a pain because of the front air dam. Amazon.com
I added the rough country Tow hooks. they fit fine and install was a breeze.
Thank You- keep you posted
I traded in my 2022 for a 2025 and had the dealer take the Mopar tow hooks off my 2022 and install them on my 2025. So apparently, they fit.
As others have stated any 5th gen tow hook set will work - I had a set on my 19 - moved to my 21, 23, and now 25 and fit all the same. It is a pretty easy install - takes me about 30min at thos point. The only real difference on a 2025 is the plastic piece on the bumper is a serious PIA to remove and ai broke mine in the process. That said there is no bezel to replace the piece you remove like there was for 19-24.
I installed a new set of the OEM black powdercoat hooks into my '25 Laramie Sport bumper - maybe 30 minutes total time, install is simple for the most part. Bezels come out easy, just takes a little finger muscle to pull down on the tabs that hold them in behind the bumper.
Biggest PITA if anything is that the long frame bolt @ side that has to come out to go back thru the the hook mount is secured inside the frame by a lock washer so it doesn't readily just drop out. You literally have to wrap a wrench around the base and repeatedly yank hard downward on it to pull it out of the washer and release it from the frame.
Doesn't take long, just a hassle... Was that way on my '21 as well, so this time I was prepared at least.
You can also just put downward pressure on the bolt head while unscrewing it and the washer will thread off. That’s how I did it.
