Thank You- keep you postedI went with crinkle black finish. It says in the description that it fits 2019-2023 but if you cross part numbers to the mopar catalog, they fit. The install is a pain because of the front air dam. Amazon.com
You mean the outer bezel rings like these?That said there is no bezel to replace the piece you remove like there was for 19-24.
Correct - not needed on a 2025 as the bumper is different than the 19-24's. I hadn't even seen a part for 2025's before. At least on my Laramie I think it is because the slots aren't in chrome anymoreYou mean the outer bezel rings like these?
You can also just put downward pressure on the bolt head while unscrewing it and the washer will thread off. That’s how I did it.You literally have to wrap a wrench around the base and repeatedly yank hard downward on it to pull it out of the washer and release it from the frame.
