New S 25 Ultra - Text Messages Will not work - UC4-12" Screen - Help
BlueHemi1500
Richmond Va
All,
I had to purchase a new phone because my old phone was stolen.
I bought an S25 Ultra on T-Mobile. It runs UI v. 7, Android v.15 out of the box. All available system updates and apps are up to date.
Out of the box - it runs Google Messages - this is the factory Text message system vs. Samsung Messages for the same function. My previous phone was an S23 Ultra running UI v.6, Android v. 14, the text system on that phone was Samsung Messages and worked without any problems.
The truck radio is the 12-inch UC v.4 running the 40.1 system.
The phone paired easily all other functions appear to work correctly.
The messages function is grayed out and gives an error message that quickly flashes and disappears. Something about the configuration of the phone, and check to see if the phone is compatible with the truck/radio system. So this results in not being aware of text messages while driving, unable to have the truck read messages to me, unable to send one of the pre-made responses, or call the message sender back from the radio screen. The phone is connected via Bluetooth, as I use the maps in the radio due to very poor cell service, so the truck maps are my only choice.
Has anybody had this problem?
What was your solution(s)?
I use this function(s) frequently while driving.
I look forward to learning about the solutions the members have to the above.
TIA
BlueHemi1500
Check your android auto settings and check Google message settings while connected to the truck.
Although I have an IPhone mine always works if I plug it in . I’ve never used Apple Car Play .
Thank you for the previous ideas and solutions.
I have verified, checked numerous settings in my phone and the truck.
What, I am asking to clarify: Has anyone solved this problem, and how was the problem solved?
It may be the new version of Android and or the lack of an option for Samsung messages may be the problem(s).
I do not use Android Auto because I live and work in the mountains of Virginia. It is very rural, and cell phone coverage is very limited due to the lack of customers and terrain. I use the built-in XM radio and navigation maps out of necessity. Yes, I know I can download maps for a given area, but I do not have the storage capacity for all the maps I would need to download and store. Also, Android Auto adds another level of complexity that I don't care to use.
Previously, I simply connected my phone via Bluetooth as this works passively by phone and truck in the same radio contact range.
I do not have an Apple phone, so Apple CarPlay is not an option.
I look forward to the collective knowledge of the members here.
BlueHemi1500
I have a Note 10+ which message works fine. Not that it helps you. But my friend has a S25 Ultra and was having the same problem on a jeep. He said his phone did't have the Samsung message. They are making us all switch to Google Message very soon. So he was able to download Samsung message from the Samsung store. He said it works now, and had to first delet his phone and then pair it again with his Jeep. So look in the Samsung Store and see if you can download the Samsung message app.
By the way my phone was bought direct from Samsung unlocked at the time. I have had t-mobile for a very long time. But I am going to be pissed if they finally make me have to use Google message, and if they remove the Samsung message app from their store. Which I am told they are going to do. I am pissed that I am going to have to buy a new computer by October because I can't download Win 11 onto my Lenvo All in One. I don't have that T-1 chip.
Thank you for the confirmation on Google Messages.
I knew someone out there had already had the solution.
To switch to Samsung Messages = losing all the various settings for the various contacts, and that is a time-consuming monster, after having to rebuild the new phone mostly from zero, not all of the backup data was imported correctly.
I had that suspicion, that was the problem, and not the new phone, new UI, or the new Android version.
You are correct that with the S25 series of phones and a new version of Android, Google is now the default standard.
I will just live without the ability to respond to texts while driving. Google does have some technical benefits in the backend vs. Samsung Messages.
BlueHemi1500
