Alignment specs?
SgtSlaughter
Can't find my alignment sheet to post a pic but I know im running 5.2* caster.
Running superlift upper control arms, fox 2.5's, 285x75r18 on Icon 18x9 5" backspacing -1mm offset.
I just rotated my tires and now they're rubbing again. Ive already trimmer the hell out of my inner fender liners and the tab that protrudes from the pinch weld.
Does anyone have any alternative alignment specs or recommendations for an additional 1inch lifted non-air ride rebel?
Caster shows 4-5.3 on my sheet and mine is currently running at 4.1. I have no rubbing on 275/70-18, but you're running a 1.5" taller tire, so that would eat up some of the space I still have remaining.
i didnt rub at all when i was running low 4s caster. Now I’m “corrected” at the higher end and it rubs slightly on reverse/full lock.
If you can live with it, lower caster.
Shop was about to get me down to 4.7 and 4.3 and it fixed a lot of the rubbing I had.
Previously I was rubbing at 5.3 caster.
Thanks for the info
Thanks for the info
Mine was at 5. I just had them take me down to around 4.3 and it feels better and rubs way less.
Here's a stock limited with air ride for reference.
Keep in mind, air ride calls for different toe specs. Total on non-air is .10. But caster and camber should be pretty much the same.
I was just gonna reply..that's a lot of toe..but didn't know air ride has so much more.👍
