SD Rebel
Also, he doesn't say higher viscosity increases wear. He said it increases temperature (which I never noticed in my truck). He did say, sometimes higher viscosity doesn't lead to less wear in the UOA's he saw, that's not the same as saying increases wear.
The UOA's I've done personally on mine, and seen on ramforum ... they all show the hemi responds very well to increased viscosity. He is talking in general terms, if you have a honda civic running in the city and never getting up to temps, higher viscosity isn't going to help in that case.
He mentions that earlier in the video about the heat, but he clearly summarizes at the end "Just because you increase the viscosity doesn't mean you get better engine protection". You are right, he didn't say higher wear, specifically he said "that an increase in viscosity doesn't equate to lower wear metals ".
Which in the end doesn't mean we should be jumping to a higher viscosity, this was your quote: "Bottom line, you should be running higher viscosity in the hemi's.", yet this was his quote: "Just because you increase the viscosity doesn't mean you get better engine protection" and don't go and start changing your viscosity without research was his point at the end.
You probably didn't watch the end of the video before posting it and using it as proof, don't worry, you could still be right in the end to go to a higher viscosity, but that's not what this video is saying.
I love sparing with you Silver, and I may join you in the dark side one day, but right now I'm going fishing on my Waverunner
