New 5th-Gen 1500 Fuse / Relay / Circuit Breaker Diagrams & Documentation
Mine is 2024. Im gonna try both options and let u know what works with it. Thanks for ur posts..............(y)(y)(y)
You’re welcome. Definitely don’t think what I posted will work for you. 2025 is new and different from previous years.
There was talk about putting an in line tap to kill the USB ports once the truck is off. However, there doesn't seem to be one for a 3 min fuse.
I posted a diagram for the Internal Fuse Panel recently. This was good information to share with other 5th-Gen 1500 owners because the owner's manual doesn't contain such a diagram and the labels on the panel are very hard to read.
However, there was a lot more information that could be even more useful such as a diagram for the External (Engine Compartment) fuse panel as well as better detailed information about all of the fuses, relays, and circuit breakers. This took a while to compile but it was worth it because it will be a handy reference for anyone who could use it.
I created the information in a spreadsheet database and then published it on the internet. From here anyone can reference it any time online. I've also created two pdf document files if you wish to download the information directly to your computer or your smartphone. You can print a hard copy or keep it on your smartphone to access it easily if you ever encounter any issues on the road.
The website and the files both contain detailed information about both the Internal and External Power Distribution Centers, much more than the owner's manual or any other such documentation I could find. For example, you can now very easily find all fuse and relay locations and reference with expanded detail what each one does. Instead of using the esoteric acronyms used in the owner's manual to describe the fuses and relays, I've expanded most of them to their full names. This makes it much easier to understand what each one does.
Please see for yourself. Here is the RAM 1500 5th-Gen Power Distribution Centers website.
Here is a screenshot example of the partial Fuse Description table:
Here are the included Fuse Panel Diagrams:
External Fuse Panel:
Internal Fuse Panel:
I hope you find this information useful.
Fascinating, and potentially useful. I am about to hard wire a dash cam using a hard wire kit. The dash cam would very much like to have an accessory connection as well as a battery connection. I recall (from my early 70s shop class) that fuse panels used to have spots marked ACC. My vision isn't too bad, but I am not seeing any such markings. Where can I find an available fuse that only runs in the Accessory position? Yes, I am not an electrician. I spent my life catching miscreants...
From an older thread. See if this helps you.
It’s gotten a bit more complicated from the good ol’ days….
