New 5th-Gen 1500 Fuse / Relay / Circuit Breaker Diagrams & Documentation
Same!
Yeah I’d be all over looking for one if it weren’t a warranty repair. I’m at the mercy of the process at this point. I did do a quick 2 minute search and didn’t find any in stock anywhere.
If it’s a warranty repair the dealer should be able to figure that out for you
Update on mine - tailgate module and body control module were both bad. Both were replaced under warranty this morning. A good experience with Hendrick CDJR in Concord NC if anyone in the area happens to stumble upon this post. I had to leave the truck overnight for initial diagnostics, and overnight again yesterday once the tailgate module was swapped and it was discovered the BCM was bad. All the loaners were out both times, but they booked Uber's to and from the dealer / home so I didn't have to worry.
I'm aware this is an older thread, but I've got a question. Are the empty slots labeled as "spare" useable? I've be unsuccessfully attempting to find a useable slot to add a fuse tap that is only active when ignition is on. I've pretty much tried every dang slot, and jus cannot find one to give this power. Even the used slots that get hot with key don't show me power thru the tap, only the ones that are always hot seem to work! Do I need to run the wire thru the firewall to the internal fuse panel?
This is a pic of my underhood fuse panel.
I sure miss the old days where you could take apart a truck or car completely and reassemble it better than new!
Spare is just a spare fuse, it's not wired.
The short answer is: No.
First line in this factory publication is "Ram 1500 DT trucks do not have upfitter switched battery circuits available under hood" You'll have to use a fuse tap under the dash. There is a rubber nipple passing through the firewall that you can slit and feed a wire through.
Im hearing a clicking sound when I hold my windshield washer button, when I press it to use my windshield wipers theres no click. It sounds like its a relay for the washer fluid pump but I cant find anything online about it or where its located
There have been a lot of people asking to make this a sticky so you can easily find it whenever you may need it. These requests have gone unanswered by the forum admins, so I just want to remind everyone that all the information here can always be found on this website that I created for it. The website will also work well on smartphones, so simply bookmark it. That way, if you're ever on the road and need it quickly, it will always be with you (provided you have internet access). There are also downloadable pdf versions that you can store on your computer and/or smartphone. You can also print the pdf versions (although the included links will obviously not be available).
Let me know if you would like any improvements or additions. I'm still trying to find the functions of circuit breakers CB1-CB4. If anyone knows their function or has access to the wiring schematics, please let me know.
New here.. but thanks for work on the fuses. Unfortunately, I must be the only goofball that can't figure out how to download or print the google document. First, I am not a google document fan, but after much reading, apparently when I pull up the google document you have linked, in both chrome and MS Edge I right clikc on the page and select Print. I change to save as .pdf... but it only shows the top of the page (a portion of the fuse descriptions). Everything below that is blank. I've tried everything to get the browser to display the whole page when attempting to print. Someone said to change the all pages, to custom.. but that doesn't work either. I've seen you mention there is .pdf versions somewhere. I've looked all over this thread for the links to the .pdf, but the only links are to the crappy google document pages. I'd like to download a complete copy of this fuse info. Please help. Btw, I am on a Windows 10 computer.
Hi Im new to forum. Thanks for the great information.
Im planning to install kill switch. I see when removing engine bay F40 dose the trick. Thats 40amp. Is there a better lower powered alternative? Thinking to find the source of F40 original wire from under the box n cut. Thats a risky thing to do. Any tips highly appreciated.
Is this to prevent theft or save the battery? F01 should be the fuel pump
Thanks for the reply. This is for 100% theft prevention. 😬😬
Gotcha. I would do the fuel pump so the computers don’t lose anything while the switch is engaged. Would be even easier if there is one inside to tap, but idk if there is
Great thread here. Thanks for all the insights. I’m looking to install aftermarket rear seat heaters to a 2022 Laramie. Dealer said they were in there, got it home without noticing, months passed before it was cold, then when I called the dealership my guy didn’t work there anymore. Annoyed but I figure I can handle this.
This kit came with its own inline 10A fuses, so in theory I should just be able to get power to it and those fuses will cover it. Anyone have experience doing this? I was thinking I should use one of the spots with no fuse in it like F37 and F38, but happy to change direction if anyone has advice. Thanks!
Anyone know how connect to (Fuse or wire) when steering wheel turns left or right, the fog light comes on the side of turn feature? I want to install camera system n use it to trigger left or right cameras.
Anyone know how to tap in to when steering wheel turns left or right, the fog light comes on the side of turn feature?
Just press the fog light button. They will stay on and not alternate while turning
Sorry I wasnt clear on my comment. Ive updated it bit to explain. Basically I want to find related fuse or wire I can tap in to. Thanks.
I see. Not sure which, I’m thinking you’ll have to find the wire that feeds it. I’m pretty sure the LED lights are connected straight to the ECU and don’t go to the fuse box
Very nice information regarding fuses. Just a word of advice, might want to keep a volt/ohm meter handy as well as spare fuses. Fuses don't just burn up without a good reason, which is the current draw exceeded the rating of the fuse. I would suggesting checking the ohms reading of the circuit that has just blown and do the math to determine if a new fuse will also blow or if the current draw 12V/ohms=current draw exceeds the fuse rating. If the calculated current is within 80% of the fuse rating then you may have an electrical problem with that circuit and the new fuse will soon blow as well later down the road. If the ohms is close to zero then you definitely have a short and the new fuse will blow once power is restored. FYI the slow blow fuses are usually for motors which have a large inrush of current when starting due to low resistance, as the motor increases speed so does the resistance. A slow blow fuse will work for other circuits but the non-motorized circuit will burn up before the fuse blows so not a good idea.
Just food for thought from a retired electronics engineer.
Anyone knows what is the fuse related to this? I have media box plugged to this and I know its running hour or so after turn off the car.
trying to figure out how to disable that. Thanks
Try F53, a blue 15A fuse.
Edit: This is for 2025.... I should've made that clear first!
