2019 lower control arm bushings
Juniorsaur
Hi, I’m new here and if this ain’t the place to post this I’ll delete but I was told my lower control arm bushings are torn, and I’ve been trying to find replacements for them but nothing is coming up? Do the lower control arms outright need to be replaced or just the bushings? And where would I even find the bushings
Look at Mevotech or Moog might sell replacement. If they don't, then you'll need to replace the full arm which Mevotech I know sells. I don't see anything for oem replacement.
Welcome to the forum.
Who told you they are torn?
Do you have a lot of miles?
126k miles, and the suspension guy from the dealership, which would track because I have gotten a bit bumpier ride with some noise
unless you have a shop press it will cost as much or more to pay for the bushings to be replaced than to just replace the control arm. do you have the tools /jack? if you do it's a simple bolt on than take it for a alignment. on the bright side the replacement will also have a new ball joint.
the lowers are 171.79 each on rockauto the uppers are like 80 a piece if you can afford it i would just get the whole thing.
the bushings are 8 bucks the labor is????? you still have to take them off and in my area labor is 180 a hour so if they charge a hour to press them in and out......
SUSPENSIA X13BU0251
SUSPENSIA X13BU0251
They say 4wd on the site which sucks mine is 2 wheel, but yeah I think I might just have to do the arms but 316 for parts and labor sounds better than the 8 I’m gonna pay replacing the lower control arms, thanks for showing me those though i appreciate it
mine is 2wd also. on the mopar parts site 2wd and 4wd are the same control arm same part number, from the 2019 dt tradesmen up to the 25 tungsten all models except for the TRX are the same. i also have a bushing blowing out with 72k on my truck. looks like the "spindle" changes not the control arms. i looked around 2wd specific control arm's don't exist. i hope that helps
Considering I don’t know a damn thing about most parts…it don’t help, but I do thank you for updating me hahahaha
