Front Window Door Switch Problem?
Jjg74
2019 Laramie 5.7l 105K miles
Driver side switch won't roll down either of the front windows or operate any of the mirror buttons. Rear windows can be rolled down on the driver switch and the all of the other windows will go down on their respective switches. I have replaced the switch 4 times (I thought I had bought bad switches). The replacement switches will operate everything for 3 weeks up to 4-5 months and then it reverts to being only able to control the rear windows. I replaced the battery 8 months ago - not because of this - and was then able to run everything again for 4 months.
You might need to replace the door module.
I have the same issue on my 2022 Laramie. I smelled electrical burning and tried rolling the front windows down only to discover front windows, locks, mirrors didn't work. Rear windows did.
Dealer is replacing the Power Distribution Center as they found a burnt wire. Glad I have 1 month of factory warranty remaining.
Burned up wire and no blown fuses, that is scary...
The saga continues...
Dealer found the Door Module circuit board destroyed (badly burnt) as well as the burnt wire on the PDC under the hood. At this point, they said all fuses look ok and are trying to determine root cause. Really scary they haven't found any blown fuses...yet. They said the wiring diagrams aren't correct and reached out to corporate to no avail.
Truck has been there for two weeks. They supplied me with a Wagoneer as a loaner until it is fixed.
Outside of identifying root cause, my other issue is my wife likes the Wagoneer better than the RAM.
Sounds like you might be joining the wagoneer forums...
