A/C condensate drain???
Paul B
2025 Ram 1500 Limited H/O 3.0
Since new to me with 54 miles I'm yet to see any condensate puddles on the ground.
Carpets are dry.....where the heck does it go?
Live in Florida and wife's allergies we run a/c all the time. I crawled underneath and didn't see any drain line.
Paul B
Weird. I have a wet spot under mine all the time from the A/C.
Paul B
Do a search. The line is through the fire wall into the engine compartment. Water can wick up the drain line and get into the cab if the line seal is bad.
OK, did a search, still can't find it, not a lot of room.
Anybody got any pictures??
Could it be behind all the silver heat/insulation panel stuff?
Paul B
It "was" located on the passenger side firewall close to the frame, which the water drips onto. Then it gets evaporated by the hot exhaust. Not sure if they moved it
This is where it is on my 2021.
