2025 1500 Limited doors will not lock/unlock
Yeah, let us know what the ticket says about what the issue with the cats were. FastBlackRam was referring to people who continue to drive their cars after it overheats (coolant wise) being their fault. He was responding to my post on faulty thermostats.
Oh okay sorry misread his post quickly. got the truck back last night seems to be driving fine so far, replaced both cats, I asked what would've caused this and they have no idea... this is making me nervous but I guess only time will tell...
I have a 2025 Big Horn, my doors wont lock/unlock with the fob (the lights flash and honk but the locks don't actually engage or disengage). Also the lock switch on the inside of the truck door panels dont lock/unlock either, nor does the auto lock function when over 20mph . No issues with the truck starting or running. Did you ever get any fix for this? trying to troubleshoot before scheduling 2 weeks out with the dealer.
Yeah hopefully it was something wrong with them from their manufacturer and a fluke. I can't imagine what those convertors cost. OMG! I'm still going to floor mine often! Such a thrill!
I was/am having all of the same odometer, lock, warning system alert issues with my 2025 Limited. I had to travel and left the truck at the dealer for a week and they verified all of the issues and did a “ proxi alignment.” They then drove it for 10 miles a day for 5 days and didn’t see anything reoccur. I pick the truck up tomorrow, we shall see… Will let you know how it goes.
Yeah let me know if that helps ill have to let my dealer know about that..
For the Laramie and Limited, when the FOB won’t work, the next question is whether the “key card” will work to open the doors? I realize this doesn’t help if the Big Horns ….
Any updates on this one? My Tungsten just started doing this exact same thing, too.
Well I cant say I tried the card, but I tried both fobs and the app. all three the truck was getting the signals because the exterior lights lit up and the running boards deployed on every but the locks on all of the doors did not physically lock or unlock. only when I used the actual key did it unlock only the door I using it on. then the buttons inside would not do anything either. truck started right up fine though.. tried again in about 15 minutes still having the issue. tried again in about an hour and all of a sudden everything unlocking again. never touched a battery..
It did not. They had it for a week and I go to pick it up and before I can shift into drive the error is on. I do think it’s possible it is related to moisture and a connection getting wet. I seem to notice a bit more after a night of rain and it rained the day before I picked up the truck. It also happens when it is completely dry, but I would say 80% of the time the truck is wet. Any similar timing for you ?
I feel like it has happened more after a rain or going through car wash but it has happened when not wet as well... so now im not sure haha. I just got the truck back after both of the cats were "bad". CEL came on and put me in limp mode... so im just happy to have the truck back after driving around in limp for 3 weeks... haha. truck feels great right now, no weird alerts or lights for about a week now...
I started having the door lock issue today, had to use the key and lift the locks on the other doors to open them. Has anyone found a fix for this?
none that I am aware of... has only happened three times in the 6 months I have owned it now but still makes me nervous about future issues... they did do some ignition software update on my truck two weeks ago but im not sure if thats a fix for it or not... that was supposed to fix issue with my cats but didn't and they both needed to be replaced...
I saw another post that recommended changing the fob batteries. Didn’t think this would help since interior door lock didn’t work either, but I have not had the problem since changing the batteries. At least not yet…
Just had the same thing with the locks happen, first time happening after 6 weeks of owning. On the 2025 Sport (Canada) model. Waited the ~hour and everything worked as it should. Did not touch any batteries. Also the buttons on the inside of the door did not work. The double push back hatch button worked surprisingly.
I bought a 2025 Ram 1500 Big Horn last October. From day one using the key fob for the door locks just can't work the way I have the settings set on the Infotainment center.
Set at one push of the fob to unlock the driver door only.
Sometimes this process works as programed, other times all door are unlocked. I've taken the truck back to the dealer at least twice for this issue. They claim the door locks are working as designed, which they are not. Doesn't matter time of day, how many times you lock/unlock on the same day. I've swapped fobs but, nothing has changed.
I even had one time where the door locks would not lock by using the fob or the door lock buttons on each front door panel.
25 laramie, had it since January this just happened for the 1st time today. Same symptoms as everyone else. I did pull the fuse to check it before googling and it looked fine. Will check back on it in an hour or so and see if it clears up. Seems like there's some kind of wide spread issue here though...
Earlier this week I came out of a Walmart and it wouldn’t unlock. Didn’t respond at all (no mirrors, no lights, no running boards). Had to use the mechanical key and then the truck wouldn’t start using the FOB. Used the key card that I keep in my wallet to start. Stopped to get gas not even 1/10 mile away and everything was back to working.
Today locks just quit working . Mirrors and running boards respond as do lights and horn. This is frustrating.
Can you please explain this part? You programmed a commercial key card to your vehicle? Obviously it came in handy here, but I'm also wondering why you did it in the first place?
I didn't program the key card; my truck came with the card. Supposedly it has something to do with how the phone as a key feature is setup/configured... I'm still hoping one day they'll delver that feature (that lots of us paid for).
