Today was the transfer case fluid and brake fluid change
By chance do you have the BW48-11? I'm going to plan for September to do my diffs and t-case ut just curious on the fluid used for the t-case. I'll probably get the Mopar specific Mobil LT and use Amsoil for the difs. And after seeing some of these posts on the fluid for brake flushes in like 4 short years I'll probably do that as well. Stuff looks grimey. How was yours?
Got it from Bulletpoint. They have two styles. This one is good for everything but offroad.
Why would you say that it’s not good for off-road?
I’ve used Bulletpoint mounts on my Jeep Wrangler and Gladiator with no issues what so ever. It even held my tablet without a hiccup.
I have the base audio, wanted to try something cheap for better sound. So installed the kenwood 6x9 +3.5 component set and JBL 3 ways in rear 2.3ohm. Found a Infinity dsp amp on ebay, factory refurbished for $79. At work last night, I used a anc ch01 harness, connected the wires from radio into the Infinity dsp amp and the speaker wires out to speakers. Used the yellow power wire and ground on the anc ch01 harness. The Infinity amp is 15amp, the anc in truck is 25amp so should be fine. Plugged into truck and worked, now tuning the system, is done on laptop through USB. In future I can use the infinity amp as a dsp for my entire system and it becomes a line driver, the speaker level inputs did not require resistors. It's louder now than my old 13 Ram with alpine system and the alpine system i replaced all doors and dash with Infinity speakers. If I add a subwoofer I would just need to run power and ground and connect to the rca's on the dsp amp or if i don't want to use the 35 watts per channel from the amp, can add amps and use the dsp from the infinity. Total invested right now, Kenwood 6x9+3.5 components, $200, JBL 3 way back doors $85, anc ch01 $15, infinity dsp 4425 $79 ebay, $30 for some sheets of butyl sound deadening and $20 for some self stick closed cell foam to keep door rattle down. Less than $450. Amp seems good enough for me, getting old and need to keep my hearing. Was literally plug and play, all wiring was done inside and just went out and plugged the 2 connectors in from anc in and anc out
So far this morning I replaced the front axle lock actuator and front diff fluid. First drive and was still getting service 4wd light trying to engage 4wd and it would never make the switch took actuator back off and verified the forks were in the collar. They appeared to be out it back in with bolts hand right and tried again, just sitting in driveway. It made the shift to 4wd without issue. Torqued bolts down, topped off the fluid again. Sitting in driveway again, out truck in driveway and triwd to engage 4wd. Light just flashed and never made the changed. Pulled out of driveway and tried again while moving and it shifted fine. Guess there was just enough tension sitting still, with it in drive, to not make the shift. But it appears to be working properly now. Will see if I keep getting service 4wd light over the next few days if driving. On the factory actuator, it must have gotten hit at some point when off roading. This spot on the actuator is loose and a few months ago I actually had to use my channel locks to squeeze it back together as there was 1/8" gap where it looked like one of rhe rivits had started to pop out. PXL_20250421_154658881~2.jpg
Over the weekend:
Death Valley Day 1
The Original Camp Spot... where that tower is.
There's the sign that took my door somewhere behind the truck.
Pulled into camp... secondary location
Having a 2500 on Carli doing the pre-running is always great idea hahaha
I have ZERO idea why chef used chopsticks to make steak...
Ribeye taco
Day 2
Road side find... putting the Death in Death Valley I guess
Not sure if that tree is still alive or not, but it's been standing like that for a long time.
Over the weekend:
Death Valley Day 2 - con't
truck looks a lot bigger now
Another one...
3 Chrysler and 1 Toyota. Funny is the DT and the JT used to be Toyota owners too.
Southern DV... a less explored and trafficked by tourist place.
and the tourist trap... Badwater Basin.
Recreated that photo from last year, same spot. Only Badwater Basin is not flooded
Crater
Teakettle Junction
Exploring abandoned mine.
finished up installing my Bilstein 4600's . it's a rwd truck they will be more than enough for the street. my truck has 72k on it. could be all in my head??? it seems like takes bumps better than new? after all this talk of flushing brake fluid in another thread i figured wile i had the wheel's off i might as well do that. original pads and rotors so i assume the cap has never off. i was met with BLACK FLUID so more than 32oz of fluid later she has clear fluid all the way through now. front pads are fine the outside rear pads are pretty worn, the inside looks good....so i ended up ordering front and rear bosh pads from rock. for 75 shipped. i should be good for another 70k.
no it's not in your head lol it does perform better due to different valving than stock suspension.
enjoy the improved ride quality!
lol Mopar using that DOT -1 fluid from the factory. Yeesh. Gross.
@1BADRAMLIMITED
I finished the wiring days ago, but just got a chance for day pics right now..dusk/night will be later.
(I really want to figure out how to make the Signature "brow" lights brighter/more prominent)
RC 30" Curved Dual LED & DRL Lightbar, Vice Design Reverse LED Lights, Nilight Dash Switches & Relay Harnesses.....View attachment 198216
View attachment 198211View attachment 198212View attachment 198213View attachment 198214View attachment 198215
What did you use as a power source?
I picked up a controller for my lights and train Horn just not sure what fuse to tap into.
Had some new shoes put on the other day. I’m trying out the ever popular Michelin Defender LTX MS/2. Hopefully they live up to their reputation.
Been running them for about 10Kmi now. Frustrated with OE Duratracs sliding around on wet roads. Quieter than the Dtracs and more stable in wet conditions. Added some white lettering accent.
Removed puck and put Bilstein 5100s on a couple weeks ago. Then got rub, so been out today with a heat gun, etc giving clearance. Did not rub when puck was on, but was inch higher, I wanted about 1 inch lower in front to help squat when towing, the bilsteins in front have one notch it can go up. Replaced cabin air filter, was kind of a pain getting glove box out, filter was really dirty.
I personally hate the OEM Struts/shocks as it wallows around like a boat. I'm looking forward to swapping my suspension. Bilstein are a great choice.
Too much? Oh well... a ban had to happen eventually :ROFLMAO:
I’m sorry I had to reply to this.
I realize a lot of peeps hate HOAs, however, if you lived next door to the trashy axx dude I live next to, you’d pray for one! I live out of the city limits in Joshua, Tx and this clown next door for almost 20 years hasn’t painted, planted a bush or shrub, tossed some white axx dusty rock as a driveway that gets all over my cars and truck daily, and continues to make our nice neighborhood look worse and worse regularly! Nicest guy in the world, but dumb as a box of rocks! Has no clue what his filthyness does to all our home values. So many things I wanna say about him here but it’ll get taken down quickly. So count your blessings for your HOA. Wish I had one!
