Confirm part number 68488863AA (hopefully right tail lamp/Ram box/bed light loom)
Aidan
Hi, could anyone please confirm if this part is correct for a 2020-2021 Laramie - for the right-hand side jumper cable to connect the Rambox/tail lamp/bed light wires?
I am currently swapping from a non-Ram box bed to a Ram box one so mine currently doesn't have it.
what stage in the swapping are you? im in the same boat and I need both side jumper cable connector. my truck is 2022 1500 limited. any inf would be appreciated.
I'm finally doing this next Friday (April 25th) - had some issues with the multi-function tailgate which I resolved yesterday. Will let you know how it turns out.
These are the wiring harnesses I got for the ram boxes - both sides, the right one is longer as it goes from below the right taillight across the chassis to the main connector - left rear side on the chassis under the bed.
