Tire size
Will a 27565r20 fit on a 2022 1500 longhorn?
im showing that to be almost a 34" tire. as far as width you are fine but the height may cause rubbing if your not on a level or ORG
275/60/20 fits without any modifications on a non-leveled / no-ORP(1" factory lift).
You MIGHT be able to get away with 275/65/20 with noted inner fender modifications that are posted.
From posted responses, it seems like they will fit and drive fine. But you will have rubbing in full lock or maxed suspension movements.
But I've also noticed that people with levels (1-2") and lifts still have rubbing with 34 and 35s and still require slight modifications to the inner fender.
I think once you go passed 33", slight inner fender modifications are typically needed. Wheel size and offset will also effect this!
