Engine alert at 500 miles. P301 code
ScottyMac
I’ve had my 2025 v6 Bighorn 1500 ram for 8 days…. Just got a P301 and another multi mis fire code…. Anyone know the latest on this being a widespread issue?
Good luck. There's no fix for it yet. If you take it to your dealer, they will try a software update, but the software doesn't fix anything because it's now known to be something deeper than a simple software issue. Unfortunately, RAM/Stellantis doesn't yet know 100% what is causing this issue, so there is no fix yet.
FYI: I'm in the same boat.
Take it to the dealer and make sure you keep your service invoices!
I'm having the same problem. I've had the truck for two weeks and it will be making it's third trip to the dealership for this. It only seems to be happening, on this truck, when I remote start it. Twice using the phone app and once using the key fob.
I’m experiencing the same issue. It is super frustrating. Bought a new truck to avoid trips to the dealer and it spends more time in service than on the road. No loaners are available either. It may be time to contact a lemon law attorney.
Good luck. There's no fix for it yet. If you take it to your dealer, they will try a software update, but the software doesn't fix anything because it's now known to be something deeper. Unfortunately, RAM/Stellantis doesn't yet know 100% what is causing this issue, so there is no fix yet.
Just got it back 4/6… Yup… Ended inconclusive but, as I walked out, the service manager said basically, needs a software update… shouldn’t take this long… Engineers..
Went back to the dealer today for another reset. I was told to just continue to drive it if the light comes back on since they're seeing the same codes every time. They said they'd contact me when Stellantis comes up with a solution.
No, tell them you're going to lemon it after 3 tries. Don't be sheep and follow their lame orders.
