Clock spring problems
For a 21 bighorn with heated steering, it was 68545657AB. Make sure you get one ending in ab since there is a recall on aa ones. This is complete combo switch with clockspring.
I wonder if thats my issue. I lost all all power to my left hand steering switch and rear buttons. I ordered a new clock spring and still not working. I wonder if it was the wrong clock spring that rockauto supplied.
Do you any of you have the part number for the clock spring? I tried using the one listed on the actual part and a search comes up with nothing. I just installed a new steering wheel and fear I may have damaged the clock spring. All functions work fine, no airbag light, just making a crinkling sound. And yes my truck needs an alignment, the steering wheel is not centered.
2019 Ram Rebel 4x4 Crew
5.7 Etorque
Suspension Leveling Kit
18” Method Wheels
35” K02s
Borla Atak exhaust
After seeing your steering wheel, which is by the way very cool. I went a head and got myself a similar one. I did the replacement myself , but I'm having this clicking noise but everything else works as should be. Did you figure out how to correct the installation so there is no clicking noise, or are you ignoring it ? if so, did you have any issues ? Thanks
When I added heated steering wheel to my 22 BH, I had to change the clock spring (steering module). I bought a brand new part with the connectors for the heated steering wheel. It was over $250. Within months, the left turn signal stopped cancelling. I took it to the dealer. Maybe a mistake, but I was upfront with them--told them I had chnged the module. They wouldn't fix it under warranty. Maybe they would have; but they would have replaced it with the clock spring without the steering wheel terminals. The retailer I bought the part from is now out of business. I contacted Ram/Mopar telling them this a known bad part issue and asked for an adjustment. No response. I bought a new part (AB engineering change). It works fine. Unbeliveably, the AB part was only around $60!
