Looking to install aftermarket subs
Mikewww
Hello all. New to this forum and need help. I’m looking to install 2 10” subs and an amp in my 22 ram 1500 big horn. Does anyone know where I can buy a sub box for the big horn quad cab? Seems like most boxes are intended for the crew cab and the quad cab boxes I’ve come across are not compatible for the 2022
Installed on my base audio all aftermarket speakers and key 200.4, now wanting subs. I have 3 options I am interested in, the Fox dual 10 ported box, a sealed dual 10 and there is a Net audio single ported which is really nice, but $ and don't want to raise seat. Question is, with the Fox box, does the port cause a lot of rattle etc on drivers side rear door? I had dual 12s in my 13 Ram QC in a custom made fiberglass box, but had to raise seat, sitting in back sucked, head was on ceiling. Was thinking 2 audiocontrol 10s, not sure what amp yet, wanting 1,000 watts rms so I can have 500 to each sub. Could go more, but want light dimming when subs hit to minimum. Added photo of the sealed box I was looking at.
i ran several set's of woofers in the fox box the sundowns were okay but i have audiocontrol 10's now and they have much better sq and cost about the same oh and no the door didn't rattle with well over 1000 watts. GREAT CHOICE.
I had 1 Skar Audio dual voice coil 12" with an 800 watt mono amp in my previous big horn. Solid sound for the coin. Just providing other brand options.
Link for 10" enclosures.
i looked at those but the mounting depth kinda needs a shallow mount and skar subs recommend more air space for ported than the box's provide. you can shop around and find something that will work out. if you go sealed it opens up more options.
Which Audiocontrol subs? Spike series? Was thinking those or possibly the stinger subs. Amp, can't decide, possibly a down4sound jp8, epic 1000, audiocontrol altitude or the stinger amp. Things I like about each amp, d4sound has really nice bass knob with voltage, temperature and clip light. All priced pretty close except the altitude amp is about $90 more. I was thinking possibly going bigger with amp instead of going 1ohm, get bigger amp and run 2ohm to keep better efficiency and heat to minimum.
LOL... your in luck i had a few d4s amps JP95T (it's a beast) and the jp3 cpt good for the money. and as far as the subs the i went with the 4 ohm spikes because they need the least amount of air space and i run them 2ohm on the LC 1.1500. the jp95t with a set of 2ohm spikes would be good even the 4ohm's would work nicely.
i had 1 (red) and i did 1 (gray) as a side job it's actually really good. i sold mine and ended up spending too much money.
I am for sure ordering the Fox box, is best out there besides Net $$$ audio. I just ordered a JP13 Amp, there is sale now and certain colors are $169. The dyno tests online show 1,372rms @ 2 ohm 88% efficient, 2k @ 1ohm but less efficient and can pull too many amps. So just bought the jp13 amp and run 2ohm to keep cooler and keep efficiency. Is a deal since the smallest mono amp is same price. Will get a kicker loc to tap into rear speaker wires at the key 200.4 input. Now speakers are all thats left...the stinger mc 10s are good price and higher power handling at 700rms so I may try them, not much of a waste if I decide later to upgrade, they are only $89 and good depth for that box.
my truck came with a 220 amp alt, i have a Walmart platinum agm with quality knukonceptz ofc wire and no dimming with my 4.800, 2.300 and 1.1500 audiocontrol amps as loud as i can handle.
it's look's better now than the pic during install but it's all behind the seat and ya can't see it but i still wanted it to look good........
Well, I already received the D4s jp13 amp, the ported quad cab fox box is in shipping and audiocontrol spike 10s. Now just need wires and a loc.
Anyone have 3.5 speaker pods for dash. Was wondering if makes worthwhile difference for the $130 they sell for.
i wouldn't bother with those. the stock location work's just fine with the sound bouncing off the windshield. i did upgrade the 3.5's and put a real amp on them. you could put that 130 to better work somewhere else in that system
I have a true size quality ofc 4 guage amp kit I bought few months ago for another vehicle. Should that be fine? The jp13 on dyno tests I saw, pull a max 111 amps @ 2ohm(is what I will be running the amp at). I read conflicting things about what to use. Comes with 120amp fuse block.
should be fine. i did the jp95t twice in ram's with 4 and didn't have any issues
Jp13, spike subs, fox box installed. I set the jp13 at 80hz cutoff, think i may try 60hz. The key amp when I moved dip switches to 80hz I just felt some mid bass was missing. Sounds better at 60hz to me. Bad part I have to pull my driver's rear seat to get to amp(installed it behind seat). Fox box fit like expected, sounds super clean, I wouldn't know it was ported, those spike subwoofers sound great. Probably better once loosened up. My friend set cutoff freq and gain etc, but I have feeling I am not getting all the power I have available. Subs hit hard, sound clean doing it, but this amp is just underc 1400 watts rms, some say a little more. My voltage if playing normal music, not like rap bass drops stays at 14.2, if I play bass boosted crazy bass only drops voltage to 14.0. Which is good since I haven't done anything electrical. Realistically the bass now is set to match the highs perfect, not overpowering. But I know it has more power I am missing somewhere.
