Rebel with Air Suspension - Leveling Kit or Small Lift - What are my options?
jdl440
I read through a bunch of threads here and researched some of the different options. It seems the combination of Rebel with Air suspension is slightly limiting.
Right now I'm running TRX take-offs with 1.5" spacers, which slightly rub on the front. I did some trimming and heat gun on the inner liners but probably need to do a bit more to completely get rid of the rubbing.
I've been considering a small lift 2" (may be open to slightly larger).
ReadyLift - 1.5'' Leveling Kit With Tubular Upper Control Arms Factory Air Suspension​
This kit isn't made for Rebel. One commentor mentioned he did use it on his Rebel but had a slight squat look. He was able to I guess hack the computer to get the rear higher. I'm not really into the squat look. Lower front doesn't bother me, but I do want to fit the tires better without rubbing.
PRO: Only $500+, easier install
I looked at Rough Country and BDS Lifts but still not sure if either of these are compatible or worth it. I'm not opposed to spending a few thousand, but up over $5k gets a little harder to justify.
I mostly use my truck as a family weekend car, camping, towing jet ski, and soft offroading. I have pulled a 24' camper a few times so may be interested in maintaining that ability.
Anyone else have this setup and run a level kit or small lift? Any recommendations for my use case? Or am I missing something else?
I am in the same boat, and the pickings are slim. I want to put 35s on and be comfortable. I only see the links from Revel performance, and Rough Country has a cheap Bracket to raise the front 2". For 30 bucks, you really can't beat trying out the RC's. I have a set on the way and will see how they do. Hopefully, someone puts a simple kit out there soon!
I got the readylift 1.5" leveling kit and couldn't be happier. Though the rear was lower after the install. I used alfaOBD to raise the rear and lower the front, but you could also use adjustable air links. The Readylift kit was very high quality and took me about 9hrs to install, taking my time.
I'd be happy to share more details if you want.
