Windshield Washer Pump or Clogged Nozzles
Observer_68
Welp, took my 2019 Ram 1500 Limited 4WD 5.7 to dealer for a recall ABS re-flash and had them check the windshield washer just dribbling out of the DS nozzle and nothing coming from the PS nozzle. Service seems to be sooooo slow these days. 4 hours later was informed that they suspect the little washer pump may be weak and the estimated repair was $689.85 ( IF that was the problem) so I thought "WHOA" and rejected the repair. All they did was remove the hood insulation (not completely) to check if the lines were still connected. Anyway, after I got home I began to look the system over. I disconnected the tubing where it turns at the DS hinge and goes into the hood and ran the pump with a 16oz water bottle attached and it filled it up in about 5 seconds. I could place my thumb on the tubing to stop the flow so I don't know how much pressure the pump is suppose to supply, but it seems descent to me. I'm waiting on some push pins I ordered for the insulation unit and see if I can get to the nozzles to see if they are just plugged. Does anyone else have any history with this issue and if so can you share please? My model has the nozzles connected to a 10" or so line that is under the hood near the windshield. I tried to search the forums but I seemed to bounce around in a loop, sry.
Thanks in advance!
Chase those washer fluid lines all the way from the nozzles to the pump, they use hard plastic connectors and tees that break easily. My 2016 had low pressure and found a plastic connector about a foot from pump was cracked, replaced under warranty a week later same issue. I got some metal connectors from work and install them, end of problem. 2023 same issue about a month ago, except connector was under the sound deadner in the hood broke in half.
I just did a Google search on clogged windshield washer lines and nozzles and some results popped up that Rain X windshield washer fluid is known to do this.
Thanks for your replies fellas. I've dug deeper into this issue and removed the DS nozzle assembly and cannot get anything through this, even air. How could they not check this??? At any rate, I will vacuum the reservoir out, back blow some low pressure air and try to clean the supply real good. Couldn't even clean the nozzle out with pins.. sigh, and get those nozzles ordered.... Will report when finished.
Ugh, welp, after digging even deeper into this issue I disassembled the nozzle and found a plunger and check valve ( I think) which might explain why I couldn't blow through the nozzle....... so maybe the pump is too weak to perform. I'll attach a pic for your viewing and look into ordering a new pump as well. $25 or so and a major install exercise. Any tips are welcome as well.
Just to share; after putting that nozzle back together and reinstalling it; it seems to work fine now but the PS is not. Therefore I vacuumed the reservoir out with my shop vac making sure I got all the gunk from the bottom settlling area, blew air back through the motor until I heard it spin, flushed it again and refilled it with distilled filtered water. So I took the PS apart also and found nothing again, but can't seem to get it working at all. That spring and plunger looking part must be some kind of equalizing design, dunno'. Got a pair of new ones coming (10 days for the free shipping) and hopefully that will cure things. No one local seems to carry the later model 2019 nozzles, sigh.
The little plunger thing is an anti-drainback device to keep fluid in the lines so when you hit the switch to spray it comes out immediately m. Otherwise you would have to wait a couple seconds for fluid to get from reservoir up to nozzles each time.
Ah, understand, thanks HSKR R/T. Welp, hopefully those got gummed up or sumpin' and the new ones will work without replacing that pump (which will be a bear to get to). After taking the DS one apart it seems to be working now but the PS one did not respond to cleaning so I just removed the anti-drainback on it until the new ones arrive. I will follow up with this issue. Thank you all.
