My 2019 Ram 1500 has thrown a few codes. One code, U0415, is for the right front abs sensor implausible value. This affects my traction, ABS, cruise and 4 wheel drive. Another code,B1293, is for the parktronic sensors shorting to ground. This is affecting all the sensors. I did replace the right front wheel sensor which did not help. Any idea what may be causing this. I am going to check the wiring harness today to see if I can find any issues there. TIA
